Windows wont roll up
Old Jun 21, 2005 | 04:56 AM
Maxima_NRH's Avatar
Just a quick question here for you electrician types.. A friends Maxima is burning up fuses every time he tries to roll up the power windows. Under the drivers side console fuse box, the very bottom row center column is a fuse rated at 7.5a for electronic stuff. In his car, the fuse was a 20a and it was blown out. I replaced it with one of my spare 7.5a fuses, and it blew out my fuse. Then I put in one of my spare 20a fuses and the windows went about 1/2 way up before stopping. Checked the fuse and the 20a is dead too.
Obviously there is a problem with the electrical system somewhere, but neither of us know how to troubleshoot those kinds of things.. One last thing, about a month ago, when this problem started, someone had to give him a jump start. Anyone know where we should start looking? Or is this a dealership type issue?
Old Jun 21, 2005 | 06:57 AM
Dan's Avatar
Dan
No Longer Owns a Maxima
FIrst of all it is a bad idea to put in higher fuses. Now, does this happen with all 4 windows? Have you tried lubricating the track of the window? Also see if there is any diffrence between the driver door switches vs the switches on each door. Let me know how it goes.
Old Jun 21, 2005 | 07:29 AM
Prophecy1's Avatar
Personally I d pay a dealer because most dealers will charge you a flat fee to trace all that wiring down. You could have a short somewhere. Also always stick to the stock fuses.
Prop
Old Jun 23, 2005 | 07:40 PM
Maxima_NRH's Avatar
Yep understood about the fuses and agree.. This happens with all 4 windows and the sun roof, also he mentioned that the guage cluster isn't back lit anymore so there are more problems.. He went to the autoparts store and bought a couple of 20a fuses to roll his windows and sun windows closed, burned through 4 fuses to complete the job.
I will suggest he take the car to the dealer for the electrical diagnostics, but am still hoping that if anyone's had a problem like this, where they ended up tracing the problem to.
Old Jun 23, 2005 | 07:47 PM
MDeezy's Avatar
there is a short somewhere. Was anything done before the fuses kept blowing or this just started happening all of a sudden.
Old Jun 24, 2005 | 09:34 PM
Bookum's Avatar
I have the same problem, but only with one window.not going up. Does anyone know where I can get a motor and regulator for the rear window of 95 maxima (driver side)? It seems that the typical website places do not stock that particular one.
Old Jun 24, 2005 | 10:18 PM
Nissan2k5's Avatar
bookum if u can hear somethin tryin to crank u wont need a motor just a regulator also if u hit the regulater like tap it a few times with like a screw driver or somethin sometimes thats all it needs to start workin again
Old Jan 22, 2012 | 01:19 PM
themark1's Avatar
*******PLEASE HELP**********************************
Help I have a similar problem. Yellow key light on. Cant turn on the accessory. Cant roll up windows (hard key doesn't work). I live in Alaska. 100 MILES FROM THE DEALER.
I've changed the car battery, the primary fob battery, and have tried the back up fob.
My brake lights do work.
I've noticed that the steering wheel lock is not engaging though.
All the while, though, the yellow light stays on while I'm seated in the car with either or both keys.
Yes I've tried to sit key in key boot. without any changes. Not even sure why they put that in the car.
And Yes, I've checked all the fuses.
Old Jan 22, 2012 | 02:13 PM
jtav94's Avatar
dirt has entered and is cloging the window take apart the door and clean it it happen to mine
Old Jan 22, 2012 | 03:41 PM
Amerikaner83's Avatar
bumping a 7 year old thread in a section that caters to cars three generations OLDER than yours, will yield no results for you. Keep it in the 7th gen section where you're already getting replies to your own topic. Your 2010 SV max has very little in common with 4th gen.
Fbana41
Aug 29, 2016 12:18 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
