Car's not starting! Help Plz
Old Jun 22, 2005 | 07:28 AM
Max-2-GTR's Avatar
Since a few days, I noticed that the car hesitated more and more after each start but I couldn't bring it to the garage so now, it ain't starting at all. I tried boosting it but it was useless. When I put the key in the ignition, everything seems fine:lil bip sound, dash lights on but when I try to turn the key, nothing. I don't even hear the car trying to strarting, all I hear is a lil tick sound and then nothing. What could be wrong?
Old Jun 22, 2005 | 07:37 AM
NmexMAX's Avatar
dot dot dot ...
Beat your starter with a hammer once or twice. : You most likely need a starter. Try the beating and then post back ...
Old Jun 22, 2005 | 07:38 AM
njmodi's Avatar
Do I get a tax break?
to what Nmex just said... sounds like your starter is on its way out.
Old Jun 22, 2005 | 08:20 AM
renatonetmail
In my case I had a friend w/ a 99SE and the starter seemed fine and we replace the ignition switch but nothing
Old Jun 22, 2005 | 08:55 AM
NmexMAX's Avatar
dot dot dot ...
So the significance of your post is what?
Old Jun 22, 2005 | 09:15 AM
Max-2-GTR's Avatar
Well...I changed the starter last year only....can it be something else?
Old Jun 22, 2005 | 09:21 AM
MDeezy's Avatar
ignition switch. Try beating so you'll know for sure if it is or isnt.
Old Jun 22, 2005 | 09:37 AM
99-max-ster's Avatar
i would go with the beating of the starter and then try again. im pretty sure its the starter.
Old Jun 22, 2005 | 12:57 PM
JPMax's Avatar
What's next!?..
The quality of remanufactured starters it seems is a bit hit or miss.
You may need to replace it. They usually come with a decent warranty. Still have your receipt?
Old Jun 22, 2005 | 01:07 PM
MDeezy's Avatar
if you got it from a local part storre such as adavanced or autozone, it should have a lifetime warantee.
Old Jun 22, 2005 | 04:52 PM
z32drifter's Avatar
one word of warning ..... the Maxima uses a PMG gear reduction starter. Hitting the starter.... may free it to start but can also break the magnet that makes the starter motor work..... don't do it. Very simple to test, unplug the signal wire to the starter. (follow the small wire from the starter to the gray connector) Use a test light to connect the connector from the harness to ground and have some one turn the ing switch.... light comes on... failed starter. If the light does not come on ... more than likely the ing switch has failed... You can test the switch with a test light ... same idea as the starter
Old Jun 22, 2005 | 05:33 PM
i30ds's Avatar
Armed and Dangerous
If he hears the click from the relays then its not his ignition switch... it the starter.
But then again you never know....
Old Jun 22, 2005 | 10:50 PM
Max-2-GTR's Avatar
I got it done at a garage near my house so not sure if they have warranty....g2g check tomorrow, thx for the replies guys.
P.S. I decided to leave this car to my bro and I recently bought a paseo 92 man trans to practice my stick driving before buying a g35 coupe or something like that in 2 or 3 years. So I will probably come see here less. I spent more than 2 years here and learned a lot but I had to make some change in my life and that's only the beginning!
Hehe C ya guys
Old Jun 23, 2005 | 03:47 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
get a wiring diagram, and a volt ohm meter, go to the ignition switch and check for continuity from the switch to the starter relay while slowly turning the ignition to the start position. if its bad replace the switch
Old Jun 23, 2005 | 07:27 PM
tuner001's Avatar
valve seals could be going if your max has been driven @ high rpm's for an extended period of time you can ttell if there is a cloud of black smoke when the car accually starts
Old Jun 24, 2005 | 02:11 PM
i30ds's Avatar
Armed and Dangerous
??? What the hell are you talking about???
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
