Read rotor removal how to ????
Old Jun 22, 2005 | 11:55 AM
billy bronco's Avatar
How does the rear rotor come off my 98 Max, looks like I need to remove bearing is this right?
Old Jun 22, 2005 | 12:10 PM
Bobo's Avatar
The rear rotors are removed in the manner outlined in section 9-10 of the Haynes manual. Obviously you don't have one or you wouldn't be asking this question. For the sake of $20 or less, perhaps you should invest in one, get lip burn reading it and proceed accordingly.
You don't have to remove any bearing.
Old Jun 22, 2005 | 12:20 PM
dayglo's Avatar
yup take the bearings out to start
Old Jun 22, 2005 | 12:21 PM
NmexMAX's Avatar
dot dot dot ...
It slides off after the caliper assembly is out of the picture. The rears sometime need some persuasion ... hammers are my preference.
Old Jun 22, 2005 | 12:24 PM
I30tMikeD's Avatar
There is a small screw hole in the rotor. Find a screw that fits and screw it in, seperating the rotor from the hub.
Old Jun 22, 2005 | 12:29 PM
JPMax's Avatar
What's next!?..
-Take off the rear brake caliper pistons.
-Take off the rear brake caliper brackets.
-Put two lug nuts loosely back on studs for each hub so the rotor doesn't go flying.
-Get a BIG malet or hammer
-Get under car and WHACK that rotor from the back until it pops off.
The only thing holding the rotors on is rust.
Safety warning: Make sure your car is on jack stands and parking brake is on.
Old Jun 22, 2005 | 12:38 PM
Bobo's Avatar
So does the bearing have to be removed or not? There certainly was no reference to it in the Haynes manual or in JPMax's above instructions.
Old Jun 22, 2005 | 12:49 PM
aznsap's Avatar
i've had to remove my rear rotors to replace them. once the caliper is off, i just took a 2x4 and banged it off.
Old Jun 22, 2005 | 01:59 PM
JPMax's Avatar
What's next!?..
No. The bearing does not need to be removed.
Replaced them two weeks ago on my brother's max.
Just a lot of rust build up on those stock rotors holding them on.
Old Jun 22, 2005 | 02:58 PM
Bobo's Avatar
Thanks, that's what I thought.
Old Jun 22, 2005 | 07:21 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
you'll need a BFH
Old Jun 22, 2005 | 07:37 PM
gtr_rider's Avatar
192.168.1.1
http://www.vqpower.com/v2/modules.ph...rticle&sid=136
Removal there
Old Jun 23, 2005 | 04:07 AM
Some people on this web site are quite helpful, others need to find something better to do with there time. Above worked out great, thanks for the input. Job done in 15 minutes, no more screaming dragging warped noises, thanks.
Old Jun 23, 2005 | 08:33 AM
KFL's Avatar
KFL
Originally Posted by killcrap
you'll need a BFH
If not then a bolt that goes into rotor 2extra smaller size holes..screw in bolt it pushes up against the hub and comes undwedge. Instead of pounding at a semi-seized rotor,less brute force needed
BkGreen97
Apr 2, 2016 05:47 AM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
