Question on the variable intake from a 5th gen
Old Jun 22, 2005 | 06:27 PM
DanIAm's Avatar
Is this intake manifold on 00-01 or only 01, anyway i could tell for sure other then its black and not metal...I've started full time doing internet sales at a salvage yard that i've been at off and on for many years and today i walked by the guy that strips down the motors and he asked "hey need a manifold for your maxima" full set up off a 00 maxima siting on the ground pulled off complete with all hoses and everything. Just need to know if its the right one. I know i wouldnt be paying much for it at all...any info would help
--Dan
Old Jun 22, 2005 | 06:44 PM
Bobo's Avatar
I believe what you want is the intake manifold off a 2000 Maxima giving you what is referred to as 00VI. Given you have a 96-5-speed, a lot of .orgers combine that with a JWT ECU with a raised rev limiter (say 7200) and then hold on to your hat, lol!
Do you have an aftermarket y-pipe? That is the best bang for the buck performance enhancement for a 4th Gen Maxima.
Old Jun 22, 2005 | 06:48 PM
DanIAm's Avatar
Yeah i just couldnt remember what it was called, i havent looked at doing it for a while...so 00 maxima manifold will do it then right...im gonna have to put it aside tomorrow, i was meaning to ask them if i could pull a motor apart for the manifold but for some reason they happened to pull this one apart. now to do some research and find somone to help.
--Dan
Old Jun 22, 2005 | 06:59 PM
mansurxk's Avatar
hot item, but it should be off a federal spec model
Old Jun 22, 2005 | 07:40 PM
sunten1
Just wondering...if he has the whole motor in good condition why not just do the whole swap???
Just and idea
Old Jun 22, 2005 | 08:47 PM
2 Da Max's Avatar
you could do the whole swap, but i dont thing aftermarket ecus are out for that motor. or im i wrong?
Old Jun 22, 2005 | 09:31 PM
s0ber's Avatar
Its 2000-2001
Old Jun 22, 2005 | 10:55 PM
maximazation's Avatar
you can use the 4th gen ECU with the 5th gen VQ30.
Old Jun 23, 2005 | 04:59 AM
DanIAm's Avatar
I just had this motor put in from the salvage yard, its from a 98 with 17k miles on it, no need to swap, the must of pulled the motor apart for a reason, it might not of turned over or had a cracked block or sumthin
stevesmax
Dec 17, 2020 11:57 AM
Finkle
Sep 27, 2015 09:53 PM
ef9
Aug 27, 2015 07:21 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
MaxStock
Aug 12, 2015 08:33 AM
