Max wont start
Old Jun 25, 2005 | 10:20 AM
quickie's Avatar
Max wont start
Hi, my 97 auto max will not start now. A couple of start ups prior to it not working, the car would crank over slowly, like the battery was real low. I had the battery tested at autozone and it was still good, i took out the starter and had that tested to and it was also good. My alternator was replaced about 6 months ago, so now i have no idea why my car wont start. When i turn the key over to crank it, there is no sound. Any ideas? Thanks
Old Jun 25, 2005 | 11:13 AM
dayglo's Avatar
did you look for codes?
theres not even a click when you turn the key?
Old Jun 25, 2005 | 04:28 PM
Zero9890's Avatar
Ive heard of this happening to a few people that when the turn their key, there is absolutly no sound at all. There was a few threads on here about peoples cars not starting, so if you search a few pages back you should find them. Also i think that problem for alot of them was either a bad starter OR a bad wire/connection on your ignition (right under your steering column). If there was a bad wire/connection on your ignition it would explain your starter not turning because its not gettin a signal from the ignition.
Old Jun 25, 2005 | 04:50 PM
njmaxseltd's Avatar
Slow cranks are caused by weak batteries, bad starters or a faulty or loose battery cable.
There have been issues with ignition switches going bad as well.
Old Jun 26, 2005 | 12:38 PM
quickie's Avatar
Is there any links that show how to replace the ignition switch?
Old Jun 26, 2005 | 12:39 PM
njmodi's Avatar
Do I get a tax break?
Is it in one of the stickies... 10 min job... remove the steering plastic shrouds and its there there.
02PearlSE
Oct 7, 2015 02:12 AM
neilraz
Sep 11, 2015 07:36 PM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
Balkins
Aug 12, 2015 06:39 AM
