Wheel application for z32 brake kit...
Old Jul 7, 2005 | 01:40 AM
jcy98maxse's Avatar
Turbo is too much fun!
I'm interested in getting some new rims soon but had a questions on the size. I am currently running 17x7.5 G35 coupe rims with my BBK upgrade, however I dunno what other size offset would fit with these calipers.
These are the ones I'm looking at:
Its available in a 18x8.5 +33mm offset (which from 5Zigen's chart says it fits a G35 coupe). Now my question is would an +35mm offset clear the calipers?(application for a Maxima) The reason I ask is that with these current rims, I get uneven wear on my tires therefore I would like something that maybe closer to stock spec that maybe easier on tirewear. I understand theres no perfect solution for this problem, either have one or the other but I just wanted to ask, maybe there is somebody here with my current setup that has experience with getting rims to fit better with their BBK. Thanx.
Old Jul 7, 2005 | 01:49 AM
jcy98maxse's Avatar
Actually I found the answer to my question, my G35 coupe rims are +33mm front and +30mm rear. Both fits fine and looks like +33mm is the closest I can get without clearance problems (mine barely clears). +35mm would probably not work.
Anyways, what do you guys think about these rims? $300ish each for these rims which for the size 18x8.5 weights about 21lbs which is pretty light for 18's. Anyone got other suggestion on light 18in rims that don't cost a fortune? (ie Volks are out of my price range )
BkGreen97
Apr 2, 2016 05:47 AM
bbsitum
Sep 11, 2015 04:55 PM
carid
Sep 9, 2015 05:06 AM
dcam0326
Sep 8, 2015 11:02 PM
Johnny9595
Sep 3, 2015 05:18 AM
