HID kit 9004 plug and play part questions
Old Jul 7, 2005 | 07:21 PM
Nick7455's Avatar
I got the JDM 8k HID a while back and on ends of the wires pins are attached that "plug" into out factory harness. One of the pins bent a weird way and now I can "unplug" it from the harness but I can't completely get it out of the casing....Since it is stuck it isn't connecting properly with the harness and if I hit a bump it will either go out or flicker. I have tried various autopart places but they only have domestic parts....do you know where I can get this "pin".....
UPDATE: The blue piece is what the pins push into and then that is then hooked up to the factory harness.....if you can see in the bottom 2 pics the pin has a metal piece that is bent. I fixed it by soldering on a piece of metal and now it won't move but still where can I get these pins that connect to the end of the open wire?
Old Jul 7, 2005 | 08:49 PM
Nissan 6's Avatar
Are you sure its JDM?
MikesChevelle
Mar 2, 2021 11:32 AM
schmellyfart
Sep 25, 2015 04:47 PM
BobMax
Aug 19, 2015 04:39 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
