What is this part called?
Old Jul 8, 2005 | 05:37 AM
aprentice's Avatar
I've heard of people referring to it as the shifter trim
http://i6.ebayimg.com/04/i/04/57/fa/09_1_b.JPG
but that doesnt seem to be the name because I cant find it on the site www.trademotion.com
Anyone have any ideas? I don't have an owners manual or anything so I can't referr to that, thanks.
Old Jul 8, 2005 | 06:05 AM
97BlackSEGold's Avatar
I always thought it was the shifter trim....
Old Jul 8, 2005 | 07:02 AM
JPMax's Avatar
What's next!?..
On trademotion it's called the "indicator hsng"
GXE/SE - $15 GLE - $96 wtf!
You can search for "center console" in the collision catalog and it should come up on the list on the left.
Old Jul 8, 2005 | 08:26 AM
aprentice's Avatar
thanks and WOW, the price difference between the gxe/se and the gle is incredible, didn't know woodgrain would make the price fluctuate that much..
it also says to 11/94 and from 11/94, how would i know which is right for me?
Old Jul 8, 2005 | 11:19 AM
JPMax's Avatar
What's next!?..
There should be a sticker on the inside of your driver side door which has a production date of the car. (at least my car did..)
Old Jul 8, 2005 | 11:36 AM
sdoherty_tjm's Avatar
its talking about when you car was made, if its 95, it will say 11/94. that means november, 1994
Old Jul 8, 2005 | 11:37 AM
and yes its on the drivers side door thing
Old Jul 11, 2005 | 04:33 PM
aprentice's Avatar
is the switch bezel for the drivers door pop on or screw in? i have it right now but i cant tell, i dont know how to take my old one off, i dont want to break it then not be able to put on this new woodgrain one. taking the door apart is also out of my scope..
Old Jul 11, 2005 | 08:17 PM
JPMax's Avatar
What's next!?..
If you're talking about the control unit on the drivers door that has the lock and window buttons, it is held on by a metal clip on the front.
Look at it on the replacement you have. It's in front of the door lock switch.
You'll have to slide a flat screwdriver under the trim and push the metal clip in while at the same time pulling up the front with your hand. Takes a little work as the clip tends to snag on the door material. Don't pull up too hard or you might break the trim.
Once you have the unit out, turn it over and use the screwdriver to push the little plastic tab on the wire connector in and twist. It should pop out a little and let you pull it out easily afterwards.
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
jfl330
Sep 4, 2015 01:44 PM
iflexsteel
Sep 2, 2015 08:04 AM
