Why does my new Y-pipe sound like a 1980s compact car with a hole in it's muffler??
Old Jul 12, 2005 | 05:28 PM
MaxxAddict's Avatar
Why does my new Y-pipe sound like a 1980s compact car with a hole in its muffler??
Anyone else have this prob? It sounds like shiet when I get on the throttle. It doesn't sound "clean" at all. And it's not BITC sound. It's different.
No digital camera with me to record the sound tho.........
Old Jul 12, 2005 | 05:35 PM
njmodi's Avatar
Do I get a tax break?
You probably have a leak - did you replace all the gaskets?
G4nismo's Avatar
when u rev it or when ur on the road at WOT? does it sound like the the WS sound clip on vqpower?
http://www.vqpower.com/images/ypipe/wsrev.wav
Old Jul 12, 2005 | 05:39 PM
dr-rjp's Avatar
Some Y-pipes come with three bung holes for oxygen sensors, but I think your Max only has two -- meaning, you've got an open bung hole. Plug it with an 18mm 1/2" bolt, a worn-out oxygen sensor, or a spark plug.
The other possibility is that the gaskets between the pipe fittings don't allow for a tight seal.
Old Jul 12, 2005 | 05:41 PM
MaxxAddict's Avatar
yea, all the gaskets were replaced I believe. I gave them to my mechanic -- I didn't do the work/installation.
I especially hear the sound while on the road, along it is still there when I rev I believe.
Hmm, link doesn't work for me.
Old Jul 12, 2005 | 05:43 PM
MaxxAddict's Avatar
no. i received a fed spec pipe. no extra bung hole to deal with.
That sucks if the mechanic screwed up the gasket installation....
G4nismo's Avatar
http://www.vqpower.com/v2/modules.ph...rticle&sid=124
download bottom right
Old Jul 12, 2005 | 05:53 PM
kepler's Avatar
what y-pipe did you get
MaxxAddict's Avatar
when i first started the car after i got it installed i looked at down at the y-pipe and did in fact see gases leaking from the exhaust manifold area, then it went away.....
Old Jul 12, 2005 | 05:54 PM
MaxxAddict's Avatar
the CE one
Old Jul 12, 2005 | 05:55 PM
kepler's Avatar
i have CE and mine sounds the same way only when in throttle
njmodi's Avatar
I still say you have a leak (or a bad weld/join/seam/hole in the y-pipe itself).
Old Jul 12, 2005 | 05:57 PM
MaxxAddict's Avatar
kepler, does urs sound like the one in the sound clip? I don't think mine does.
Old Jul 12, 2005 | 06:01 PM
kepler's Avatar
no mine sounds like i have a leak but only when wot i had a shop put it on and it dosen't look like the cat and y-pipe meet up right
Old Jul 12, 2005 | 06:03 PM
MaxxAddict's Avatar
my CE ypipe was a 1/2inch too SHORT! The guy had to cut and weld a insert piece. what the he!!
Old Jul 12, 2005 | 06:06 PM
kepler's Avatar
i have only herd one other y-pipe on a max at work and it sounded good but i had no idea what brand it was, have you called CE i will be calling them tomorow
Old Jul 12, 2005 | 06:07 PM
G4nismo's Avatar
yeh mine does to. its really annoying but i got an exhaust now so hopefully that will alleviate that noise a little
Old Jul 12, 2005 | 06:16 PM
kepler's Avatar
i could live with the sound on the clip, but mine sounds raspy not deep if it wasn't for the power i would put my stock one back on
Old Jul 12, 2005 | 06:57 PM
MaximaPWR
I have the same problem, ever since I bought budget.
Old Jul 16, 2005 | 02:33 PM
MaxxAddict's Avatar
Ok, I've come up with a different comparison...
a rattlesnake's rattle. lol That's the best sound I can equate it to. I looked under the car the other day. Everything is A-ok. Firm and secure.
Could it be the fact that the mechanic had to cut and weld a section of the y-pipe in order to make it fit? Maybe that's the culprit?
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
stromm
Aug 27, 2015 04:13 PM
erictown
Aug 20, 2015 08:01 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
