Driver side axle...
Old Jul 12, 2005 | 07:54 PM
JClaw's Avatar
Driver side axle...
Well got the tranny back in the car, shifter rods connected, shifts fine, only need to put the battery back in and put the tranny oil in. Problem is the driver side axle, it is a huge b*tch to shove in (as always), I put axle grease on it it only went in the first set of grooves. Any tips on how to get that in? Have someone turn the passenger side axle while I turn the driver side?
Old Jul 12, 2005 | 08:07 PM
nick's Avatar
just give it few smacks with dead blow hammer and it should pop right in !!!!
Nick.
Old Jul 12, 2005 | 08:23 PM
I30tMikeD's Avatar
No need to hit it with a hammer. The clip on the end needs to be facing a certain way, the open part of the clip needs to be up with the closed end hanging down. You don't have it put in the hub when your doing this do you?
Old Jul 12, 2005 | 08:37 PM
JClaw's Avatar
It's in the hub but I'll try it out tomorrow.
Old Jul 13, 2005 | 05:24 AM
I30tMikeD's Avatar
If it is in the hub then make sure the steering wheel is completely straight when trying to push it in.
Old Jul 13, 2005 | 05:31 AM
Stephen Max's Avatar
Sometimes it helps to rotate the shaft a bit to line up the splines in the shaft with the grooves in the differential gear.
Old Jul 13, 2005 | 05:58 AM
Tort's Avatar
compare your old axle to your new one, I had the wrong axle once and the input shaft is different and will not fit, trying to force it will only damage something.
Old Jul 13, 2005 | 06:37 AM
Kevlo911's Avatar
Kevlo for President
I had to jack up the hub so it was strait and level too, and then I pushed hte **** out of it.
Old Jul 13, 2005 | 10:23 AM
JClaw's Avatar
It's the same old axle, not a new one.
Maybe it's different because it's a VLSD? Mike, does the open part of the ring still have to be above on a VLSD?
AaronL
Nov 15, 2020 11:52 AM
boomerbrian
Oct 31, 2018 10:25 AM
03VQMAX
Nov 10, 2015 03:39 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
maximusrising
Sep 2, 2015 09:55 AM
