Bad Tie Rods?????????
Old Jul 13, 2005 | 10:30 AM
f550maranello2's Avatar
Iv been having suspension problems so i pretty much replaced everthing... now the steering wheel shakes up and down when i go over bumps... i have new ball joints and shocks and swaybar links... im thinking that tie rods could be the culprit?? anybody had the same problem?
Old Jul 13, 2005 | 10:37 AM
njmodi's Avatar
Do I get a tax break?
Did you replace the LCAs or LCA bushings?
Old Jul 13, 2005 | 10:51 AM
nick's Avatar
have your tires balanced and ask them to look for bent rim,
inner tie rods will affect the ride , but not to the point that your steering wheel shakes up and down.
More info on shakes would be helpfull, ie: does it happen at certain speed/ does it shake on smooth roads
and rotate your tires , do this first and see what happens
where in IL are you located?
Nick.
Old Jul 13, 2005 | 11:38 AM
I didnt replace the bushings... cuz i cant find them anywhere.... the wheel only shakes when i go over bumps.. it has nothing to do with bent rims or unbalanced tires.. i can go 120 mph on the highway and now feel anything untill i hit a bump.. by they way i live in Hanover Park
Old Jul 13, 2005 | 12:28 PM
nick's Avatar
you are experiencing " bump steer " and sadly many maximas suffer same problem,
lots of road feel and every bump and crack in the road is felt through the steering wheel , i've had this issue with my car fo some time , and repalcing baljoints and sway bar bushings did make a noticable difference, but i still get lots of unwanted "road feel " through my steering wheel , it is pretty annoying , but i've learned to live with it
Nick.
Old Jul 13, 2005 | 02:30 PM
where can i find the control arm bushings? iv looked everywhere
Old Jul 13, 2005 | 02:37 PM
njmodi's Avatar
cattman performance sells ES bushings, or suspension.com, or courtesyparts.com, or ebay.com...
Old Jul 13, 2005 | 06:35 PM
Loe max's Avatar
Lift up your car and wiggle the front wheel. If it visibly moves with little ease, then take off the wheel and inspect the tie rod.
Old Jul 14, 2005 | 02:38 PM
bradt's Avatar
First time I've heard it called bump steer.' Are new or should I say newer Maximas the same way? I've got a 2K pAssat(50K) that drives like a dream while the Maxima(80K) can jump all over on the wrong roads.
And, was it worth new bushings and ball joints or is it inherent to the car?
Thx in advance.
Old Jul 14, 2005 | 03:25 PM
Loe max's Avatar
The power of four-link front suspension
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
