Just installed my turn signal mirrors
Old Jul 13, 2005 | 05:47 PM
maxedout95's Avatar
I just installed my turn signals mirror shells and after about few minutes my fuses
blew. Is anybody have any suggestions?
Thanx
Old Jul 13, 2005 | 06:28 PM
86maxima96's Avatar
I Broke OT
sorry, but i'd just like to see a pic if you have one. but i can;t help you on the wiring problem there. sorry.
Old Jul 13, 2005 | 06:53 PM
Chickan's Avatar
check your wiring? check for loose cables? check to see you used the right fuses?
Old Jul 13, 2005 | 07:13 PM
sunten1
Make sure nothing is shorting...
Here is a link to a guide for installing those shells
http://members.***.net/sunten1/LED.doc
Old Jul 14, 2005 | 11:26 AM
maxedout95's Avatar
I wired everything just like the instruction says.All I got in the package was the short wire that came with the mirrors and nothing else do I need to by a harness or a special relay for led bulbs or resistor I don't know.
Thanx
Old Jul 14, 2005 | 11:28 AM
maxedout95's Avatar
I checked my wires and there look fine I replaced all my fuses and everything is working when I unhook the wires from the mirrors but as soon as I hook them up again they blow.
Old Jul 14, 2005 | 04:00 PM
maxedout95's Avatar
Sorry I don't have any pics right now
Old Jul 14, 2005 | 05:20 PM
86maxima96's Avatar
I Broke OT
that's fine. I was just curious.
Old Jul 14, 2005 | 05:44 PM
sunten1
Can you show us a picture of what it came with?
Old Jul 14, 2005 | 06:47 PM
maxedout95's Avatar
I got it from redlinemax.com It came in a box with a picture of a nissan. The only things that were in it was the shells and little kit to clean the shells and that's it no wiring kits or even instructions. That's why it took me so long to do this.
Old Jul 14, 2005 | 07:46 PM
chenzarino's Avatar
how did you wire it? Do they work at all or do they blow right away?
Old Jul 15, 2005 | 06:55 AM
maxedout95's Avatar
I wired it straight from the mirrors to the turn signals. They work for a little bit but as soon as I turn the Hazards on they blow. I used to have a different relay for turn signals and it seemed to not burn the fuses as fast. It got me kinda frustrated cause I tried like almost everything and I had to take the door of like 5 time already and I can't figure it out.
Thanx for your help
Old Jul 15, 2005 | 06:59 AM
Nick7455's Avatar
Had mine for couple months with no problems....How exactly did you get the wires from the back of the mirror to the turn signal? Did you take the mirror off and put the wires through the little hole....I guess the mirror could be pinching the wires causing a short.
Old Jul 15, 2005 | 07:38 AM
maxedout95's Avatar
That's exactly how I did it I took the mirror off and fed it through the hole.You think that that might be it but I can't see any other way to do this
unless I would have to drill a hole in the original shell.
Old Jul 15, 2005 | 07:42 AM
Nick7455's Avatar
No...the way I described is how I did it and there hasn't been a problem....how did you tap into the turn signal...did you try messin with that connection.
Old Jul 15, 2005 | 07:50 AM
maxedout95's Avatar
I stripped the green wire and wrapped the wire from the mirrors around the green turn signal wire.
Old Jul 15, 2005 | 09:04 AM
Nick7455's Avatar
The color might be diff on 99....I don't remember green but you might have better luck using wire taps....also what did you use for the ground on the mirror covers? Anytime my fog light fuse has blown it has been because the ground was loose.....maybe there is a little interferance with the ground....Pics would help if you have them of where you grounded it
Old Jul 15, 2005 | 09:56 AM
maxedout95's Avatar
I've taken the black wire from the LED mirror shells and grounded it to the screw holding the inside door handle on. This seemed like a good place to ground the LED mirror shell.
Old Jul 15, 2005 | 10:54 AM
Iron Scimitar's Avatar
Tha Snatcher
i grounded mine to my FTSB.
Old Jul 15, 2005 | 11:15 AM
maxedout95's Avatar
Did you run yours straight from the shells to the turn signals without anything.
Old Jul 15, 2005 | 04:54 PM
dontcrossme's Avatar
Try a multimeter and make sure you have the ground and the right amount of voltage going to the wire. If your pulling too much ur going to short the fuse. try running a higher awg wire than it suggests.
Old Jul 15, 2005 | 06:14 PM
maxedout95's Avatar
I'm running a 16 gauge wire
Old Jul 18, 2005 | 01:05 AM
Nick7455's Avatar
Odd....sounds like everything is
Maybe try to rewire the extra wire you added to stretch the line to the blinker......not sure what else man..
Old Jul 18, 2005 | 01:00 PM
maxedout95's Avatar
Do you know if I can get a special relay for this set up?
I was thinking of running a extra wire from the fuse box to the turn signals but that would be my last option.
ThAnx for your help
Old Jul 19, 2005 | 05:14 PM
Nick7455's Avatar
ThAnx for your help
You prbably could but I don't see why you would need to ... there has to be an easy explination as to why the fuse is shorting.....everyone else that has the blinker mirrors hasn't had a problem....i would triple check ALL hookups...there is bound to be something loose or off somewhere....
03VQMAX
Oct 2, 2016 09:36 AM
JRod28
Feb 4, 2016 11:07 AM
Maxilano
Aug 31, 2015 07:33 PM
kirkhilles
Aug 8, 2015 10:53 AM
wpr
Aug 5, 2015 03:28 AM
