how can I tell if my ball joints need to be replaced?
Old Jul 17, 2005 | 11:40 PM
kingrukus's Avatar
no more maxima...
How can I tell if my ball joints need to be replaced? Any specific noises or other symptoms to look for?
Old Jul 18, 2005 | 12:07 AM
DR-Max's Avatar
You can tell if they need replacement if they show signs of grease leaking from it or cracks/splits from the rubber. I inspected mine while I was removing the driver-axle a while back.
Old Jul 18, 2005 | 07:31 AM
nizmo's Avatar
dude, usual symptom of bad ball joints is that when you are making a turn and go over a bump you hear a clunk/knock noise.
Old Jul 18, 2005 | 10:42 AM
f550maranello2's Avatar
actually one of the most common signs is when ur steering wheel shakes when going over bumps.
Old Jul 18, 2005 | 11:02 AM
BORQUA79's Avatar
nycmaximas member
What kinda money is involved in replacing a ball joint??? Im not sure if thats the problem with my car but when I press the brake I hear a clunk sound??? The brakes were replaces along with the rotors about a couple months ago...
Old Jul 18, 2005 | 11:11 AM
nick's Avatar
if you have lots of miles on your car ( over 100K ) i would advise on replacing balljoints/sway bar and endlink bushings along with LCA bushings and inner tie rods
all those parts are normal tear and wear and should be on everyone's list
especially if you want smooth noise free ride.
balljoints could be replaced for around $60 a pair plus your own labor, just rent the press from Autozone
LCA bushings and inner tie rods are pretty easy to replace , look them up on Ebay
Sway bar bushings and endlinks make huge impact on ride quality.
Nick.
Old Jul 18, 2005 | 12:18 PM
Phishy11's Avatar
I had mine replaced about 25K ago for pretty cheap. You can tell if they need to be replaced if the car shakes, bumps, or turns when going about 50mph or over. Better safe than sorry.
Old Jul 18, 2005 | 12:25 PM
kingrukus's Avatar
no more maxima...
So if I simply replace my entire LCA, it should take care of both the ball joints and other misc bushings?
Old Jul 18, 2005 | 01:13 PM
SPiG's Avatar
SomePsychoGuy
That will take care of most of them. The LCA bushings will be included, but the ES ones are better I am sure. It will replace the ball joint. And the sway bar bushings will be 2 minutes extra if you change the LCA.
The Tie rods are somewhat seperate, but should be easy while doing the process.
Old Jul 18, 2005 | 01:37 PM
MDeezy's Avatar
Forgive me for my ignorance in the following post.
I've been always hearing a loud clunking but thought it was my axle for some reason. Where exactly is the ball joint? I believe this is located on the lower control arm but I'm not sure. I'm going to check the how to's to see if there is a write up. I've had this noise for quite some time but thought it was something else, this would be good for me to do when I change my axle plus put my new suspension on soon.
Old Jul 18, 2005 | 01:41 PM
MDeezy's Avatar
hey I just found a write up for changing the ball joint.
Originally Posted by autozone
The lower ball joint is not replaceable, if the ball joint is defective the lower control arm or transverse link must be replaced.
http://autozone.com/servlet/UiBroker...3d801f58ea.jsp
Old Jul 18, 2005 | 02:07 PM
SPiG's Avatar
SomePsychoGuy
Technically you can press out the ball joint and put in a new one, but Nissan says you have to replace the entire LCA. It was much easier on 3rd gens though.
Old Jul 18, 2005 | 02:10 PM
MDeezy's Avatar
I was reading the write up for 3rd gen, would be cheaper to press out the ball joint and put in a new one. I'll more than likely just swap out the whole control arm, have all new bushing etc, and safly I might as well do the passenger side also instead of having one side no probs and another side so so, or is that crazy talk.
a write up for control arm changing for those who need it
http://autozone.com/servlet/UiBroker...3d801f5924.jsp
Old Jul 18, 2005 | 02:44 PM
MAXRB8's Avatar
My mechanic is replacing my ball joints (4th Gen) as we speak or at least he's waiting for the parts, the dealer told him they only sell it with the LCA but he agreed the ball joint can be pressed out and replaced which is waaaay cheaper so I order my ball joints from:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
I guess we'll soon find out if it can be done without purchasing the whole LCA
Old Jul 18, 2005 | 05:56 PM
Coolbrew's Avatar
Hey let me know if the items you bought work for you. My mechanic said I have a loose ball joint not sure which one, but it would be cheaper to replace them with $31 + install...thanks
Old Jul 18, 2005 | 09:12 PM
kingrukus's Avatar
no more maxima...
How were shipping costs to Canada? Any additional duties? What shipping method did they use? I wish I was american for the sole purpose of easy e-bay shopping.
Old Jul 20, 2005 | 08:53 PM
BORQUA79's Avatar
nycmaximas member
I needed to know... Whats the ES ones? And are we replacing the Lower control arm or just the bushings? That clunking is coming from the worn bushings or the accual assembly? Im a little confused
Old Jul 21, 2005 | 07:44 AM
klaustah's Avatar
just curious, if you replace the ball joints and what not, do you need to realign your car or anything?
Old Jul 21, 2005 | 07:55 AM
nismomax98's Avatar
Yes u do, and i just did my LCAs and inner tie rod and got an aligment got it off ebay good deal and fast shipping. I used a guy from florida dont remember the exact name sorry
If any one needs right side inner tie rod i have one for sale brand new
Old Jul 21, 2005 | 08:08 AM
klaustah's Avatar
awww boo i just got an alignment done yesterday, and i think i might need to change the ball joints, i guess ill ask my mechanic and see if i really need them changed. does it damage your car if they are worn out? or is the ride just crappy?
Old Jul 21, 2005 | 08:50 AM
MDeezy's Avatar
Waiting to hear back about pressing the joints out. I would love to just replace them and have a brand new control arm in there, but that costs more. I'm going to get one of those lifetime alignment deals, cause I know I wont be able to change my control arm at the same time do the axle and struts, then tranny a few months down the line.
ES are the energy suspension. The Bushing is of better quality and make for a better ride.
Old Jul 21, 2005 | 04:42 PM
BORQUA79's Avatar
nycmaximas member
thanks alot for the info MDeezy.... I saw these at Courtesy Nissan is that all I need to do the LCA's or is there other hardware or parts needed to fix the bumping and noise up front???
Courtesy Nissan ES
Old Jul 21, 2005 | 06:36 PM
njmodi's Avatar
Do I get a tax break?
Courtesy Nissan ES
Those parts shown in red are all the bushings (LCA, swaybar and swaybar endlink). If you want LCA ES bushings, I have a set I won't be using. Shoot me a PM. (They are new in box).
Old Jul 21, 2005 | 07:53 PM
bigdog97max's Avatar
i think i need to replace the ball joints/LCA, how much should i expect to spend for the LCA's. what's a good price, i saw some on ebay for $70 a piece and i was wondering if that's a decent price
Old Jul 21, 2005 | 08:12 PM
njmodi's Avatar
Thats the best price around (as far as I know). OEM Nissan LCAs cost ~ $200 each.
Old Jul 21, 2005 | 11:03 PM
DR-Max's Avatar
Think about this: what keeps the steering knuckle (spindle) connected to the LCA??? The ball joint! If they are worn out and you keep driving them that way, they will eventually fail on you. When that does, bye bye steering control. And the spindle or LCA, or both will be saying hello to the ground, then you'll have more to replace than just the ball joints. Replace them as soon as you can.
Old Jul 22, 2005 | 09:09 AM
MDeezy's Avatar
Excellent Point. Better to replace the control arm or Ball joint now, than the WHOLE CAR later.
Old Jul 22, 2005 | 10:33 AM
kingrukus's Avatar
no more maxima...
Very good point. Anywhere else to get cheap LCA's from other than EBay? The shipping to Canada is simply too much.
Old Jul 22, 2005 | 03:10 PM
knight71's Avatar
Didn't you read my PM :..I'm from T.O also..like i said, I can get you ebay LCA's from a local part store..let me know when you're ready to order.
Old Jul 25, 2005 | 03:07 PM
kingrukus's Avatar
no more maxima...
Hey, I read your PM the day you sent it and also replied to it twice now...can you please check your inbox? I am definitely interested in purchasing the LCA asap.
Thanks,
Phil
Old Aug 11, 2005 | 07:00 PM
kingrukus's Avatar
no more maxima...
Well I got the new control arm locally for 98.90 cdn plus tax...seems to include ball joint and lca bushings. Now anyone know the size of sockets required to remove the LCA?
Old Aug 11, 2005 | 07:21 PM
nick's Avatar
I will make a write up on saturday, but basically you'll need: 36mm axle hub socket, 22mm socket for 6 transverse link bolts ( LCA), 27mm open end wrench for LCA nut,
17 and 19 mm for strut bolts and puller for seperating outer tie rod from steering knuckle. 14mm for endlink nut, and balljoint nut is 17 or 19 mm
new cotter pins are must.
Nick.
Old Aug 11, 2005 | 07:33 PM
kingrukus's Avatar
no more maxima...
Nick.
Thanks. Did you use an impact wrench or have to use a torch to free any of the bolts? I noticed that you live in the NE, and so your car must have been exposed to the same salt/snow that mine is every winter. Also at any point did you have to remove the ball joint that was already attached to the new control arm for the install?
Old Aug 11, 2005 | 07:41 PM
nick's Avatar
I've used lift and air tools, but this job could be done with good breaker bar.
No , there is no need to remove the balljoint from LCA, just take the nut off and slide it in the lower portion of steering knuckle.
Nick.
Old Aug 11, 2005 | 07:49 PM
kingrukus's Avatar
no more maxima...
Nick.
Also, am I supposed to be able to easily wiggle the ball joint with my hands? It seems damn near impossible.
Old Aug 11, 2005 | 08:15 PM
nick's Avatar
I will have writ up for this with pics either sat evening or sunday
once you brake loose the balljoint nut , leave it on the balljoint and give it few good smacks with hammer, that should brake it loose from steering knuckle.
PB blaster helps too....
Nick.
Old Aug 11, 2005 | 10:00 PM
njmodi's Avatar
The new one should be really tight. That is normal.
Old Aug 13, 2005 | 11:40 AM
nick's Avatar
LCA write up
http://forums.maxima.org/showthread.php?t=422951
Nick.
Old Aug 17, 2005 | 03:44 PM
Fulltone74's Avatar
Hello all:
I got a quote from Courtesy Nissan in Texas for the control arms. The parts guy mentioned that the list price was $180 each but they actually sell them for around $140 each plus shipping. And they include rubber bushings and ball joints.
Old Aug 17, 2005 | 03:49 PM
nick's Avatar
yes, new LCA's come with bushings and balljoints, get 2 LCA's form ebay for price of one OEM.
Nick.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
