Back end kicks out
Old Jul 20, 2005 | 01:27 AM
Umass021's Avatar
Back end kicks out
I notice now that when I got over bumps sometime that my back end will kick out a little. I know I need new shocks soon but I wasn't sure if that was the reason why. What eles could it be?
Old Jul 20, 2005 | 01:41 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Buy a sway bar.
Old Jul 20, 2005 | 03:57 AM
lilaclucymaxima's Avatar
Team Ramrod
Same thing has been happening to me for a while. STAY OFF THE HIGHWAY. Anyway, it's because my rear driver's side shock is leaking. I doubt a sway bar would fix the problem. Replace your struts or upgrade. I'll be getting coilovers within a few weeks. Hope this helps
Old Jul 20, 2005 | 06:34 AM
nosispower's Avatar
If you're getting a lot of snap oversteer, a sway bar would make things worse. It definetely sounds like your struts are just worn out.
Old Jul 20, 2005 | 08:32 AM
MDeezy's Avatar
Dont want to make a stiff rear stiffer with a sway bar.
Old Jul 20, 2005 | 08:45 AM
MaximaSE96's Avatar
Maxima Owner
Originally Posted by SEmy2K2go
Buy a sway bar.
i think he was being sarcastic.....anyway replace ur struts and away u go
Old Jul 20, 2005 | 09:01 AM
Coolbrew's Avatar
I have the same problem and it is more than a little kick out. Are you saying to replace all ....front and rear struts?
Old Jul 20, 2005 | 09:30 AM
madmega's Avatar
ive got the same issues but i just changed my struts about 4 months ago, so what could be causing that now,, because i have to be extremely careful when i go over a bump on the highway
Old Jul 20, 2005 | 09:40 AM
Jeff92se's Avatar
I'm needing a caw
Welcome to minivan rear suspension.
Old Jul 20, 2005 | 09:45 AM
liqidvenom's Avatar
brotherhood of tq
u wouldnt have this problem if u bought better rear tires for ur high boost supra....oohhh wait this is the maxima board, i really have no advice for u then about this sorry
Old Jul 20, 2005 | 10:04 AM
smokeyone's Avatar
I had the same "kick out" feeling when my rear struts were blown. Installed Illuminas and S-techs. Problem solved, well, as solved as its gonna get.
Old Jul 20, 2005 | 10:21 AM
2 MaXiMuS 4's Avatar
Maxima.Org's Official Lurker
i get the same thing...whenever i'm on the highway on a curve and hit a bump, my rear kind of does a fishtail. I don't think its the struts, I think it happens because of our multi-beam suspension...anyway, I remember a thread similar to this and it was said that a fstb would get rid of the problem. I'll see if I can dig it up
Old Jul 20, 2005 | 10:41 AM
wannaboostbad's Avatar
Ur multi-beam suspension is starting to give out. Lift the car and check out the coil springs the shocks and the Pan-Hard bar, its the thing that looks like a pan taht goes diagonal from the bar to the frame up top. ****Teacher told me that the bushings when worn will cause it to somewhat kick the back end out***** I went to UTI.
Old Jul 20, 2005 | 07:45 PM
sonicrunch's Avatar
It's the struts. My Stanza did that, until I replaced them.
Old Jul 20, 2005 | 08:05 PM
KNYFE's Avatar
It will kick out a bit due to torque. Happens to me regularly when I hit a specific bump on a corner with a bit of speed.
Old Jul 20, 2005 | 09:11 PM
Supermax95's Avatar
happens to me when im going 130 and i pull the ebrake and turn, then ofcourse i slide into a wall. Ummm.....dont get a rear-sway bar for now. and check your shocks.
Old Jul 20, 2005 | 09:34 PM
Donald199's Avatar
It is your shocks
Old Jul 20, 2005 | 09:45 PM
DAVE Sz's Avatar
Hooooooonda.....
Buy a sway bar.
Doesn't a sway bar increase the chance of rear end kick outs?
Old Jul 20, 2005 | 10:56 PM
99Automagic
Why yes it does.
Old Jul 21, 2005 | 08:48 AM
Black Maxima
Would shocks like this: http://www.zippyvideos.com/108984619655225.html make the back end kick out?
Old Jul 21, 2005 | 09:47 AM
MDeezy's Avatar
They dont seem blown to me just a very soft suspension setup. You on stock? or Tokio Blues?
Old Jul 21, 2005 | 09:50 AM
Jeff92se's Avatar
I'm needing a caw
You guys can't avoid it unless you just settle for stock springs/shocks. The rear beam suspension won't allow each wheel to act independantly of each other. No way around it. Bumpy roads will make the rear end skitter on these things. The again, one should't be doing crazy stuff on bumpy roads anyway
Old Jul 21, 2005 | 10:25 AM
madmega's Avatar
well for u guys who saying to change struts/shock, or stay stock, i am stock and i just replaced mines recently, and it still happens
Old Jul 21, 2005 | 11:10 AM
99Automagic
My head must be in the gutter, but it looks like you're making sweet sweet love to your max. As you should, you should love your Max and show it affection.
Old Jul 21, 2005 | 06:09 PM
Black Maxima
I'm running stock suspension. I'm hearing noises all over. I'm going to drop it soon anyway...
I know I love my Maxima so much. I had another post with that video. I told people it looked like I was humping my car. But, nobody seemed to wasnt to see it.
Old Jul 21, 2005 | 06:43 PM
AxisKill's Avatar
Black Maxima lemme know how new setup works for you.. i've noticed that my max has been having a bit of a mind of its own when on the highway (fast lane 70-80mph) and the road becomes a little twisty..
But just yesterday i went for a ride with my friend in his 430CLK vs some 330 beemer and the same twisties i go over on my car at 70mph or so (driving casually) felt like a breeze at 80+mph in his while going against the beemer.
In no way am i saying my stock suspension 8 year old car should be handling like a benz.. but it definitly shouldn't have its *** leaning into the other lane the way it does..
Old Jul 21, 2005 | 06:58 PM
Black Maxima
Yea talk about a shytty suspension. Having a 3 people in your back seat going down the highway seems like you have 10" wheels in the rear and 30" wheels in the front. And I bottom out constantly.
JRod28
Dec 29, 2023 09:56 PM
boomerbrian
Nov 8, 2015 05:10 PM
kingw323
20
Oct 21, 2015 08:36 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
