Cold start problem...
Old Aug 1, 2005 | 08:18 PM
DaEnigma's Avatar
I just recently have been having a small problem at startup and I am hoping you all can help me figure it out.
When I go out in the morning and start my car it will start but then the idle will go up to ~1500rpm and move around a bit +-300rpm and the engine will sound/feel like it is stumbling. Then if I start to drive (when it is till cold ~2min after start) the car will hesitate and bog sometimes backfiring if the rpm drops low enough, but once the temp gage move past the lower hash it is normal again no trouble at all... I have no CEL and no codes also the car has 47k on it. This just started after I did an oil change, spark plug change, air filter cleaning, and fuel filter change (I had the codes checked when I did my tags ~ 2 weeks after all of this was done).
Old Aug 1, 2005 | 08:32 PM
killerVQ30DE's Avatar
It could be your Engine Coolant Temp Sensor... if this is starting to fail.. it will give wrong temp readings and will make the car think it is either overheating or to cold. Sensor is in your upper radiator hose, the stickies tell you what the normal operating parameters should be for you to compare.
Old Aug 1, 2005 | 11:42 PM
DaEnigma's Avatar
I will check that out... The FSM has the specs of the CTS also correct? Also if there are any more ideas I am open to suggesstions!
Old Aug 1, 2005 | 11:46 PM
Jeff92se's Avatar
I'm needing a caw
Whatever it is, I'm not getting in the trunk again.
Old Aug 2, 2005 | 03:30 PM
DaEnigma's Avatar
Bah I thought you liked it back there!
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
tardrex
Sep 11, 2015 07:35 PM
trungg86
Sep 4, 2015 04:58 AM
