Wtf! Why does my car clock randomly reset itself???
Old Aug 3, 2005 | 05:49 AM
MaxxAddict's Avatar
This happened for the third time. Yesterday, I hopped in my car after not driving it for a couple of days, and I noticed the clock said 1:00! (not 12:00, which I thought was wierd.) The correct real time was clearly 7:30. Once again, I had to set the correct time.
Maybe a short? Any other explanation? Thanks!
Old Aug 3, 2005 | 06:00 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
a short will blow a fuse. check the battery first for loose connection. then i would check the dimmer switch.
Old Aug 3, 2005 | 06:05 AM
MaxxAddict's Avatar
*checks the dimmer switch*.... hmm, yup! it works!
How exactly does one "check" the dimmer switch?? You mean like pull apart my dash?
battery seems good.
Old Aug 3, 2005 | 07:52 PM
MaxxAddict's Avatar
bump bump....
Old Aug 3, 2005 | 07:57 PM
PAREDLINE's Avatar
my car reads 1:00 when the battery is disconnected. I think thats the default time. Check the harness behind the clock
Old Aug 3, 2005 | 08:02 PM
njmodi's Avatar
Do I get a tax break?
to that. The clock will read 1:00 after loss of power. It sounds like the power wire to the clock is loose/intermittently disconnecting (or you have a bad solder joint).
Old Aug 3, 2005 | 08:08 PM
2 Da Max's Avatar
check the electrical parts fuse..no wait thats if it doesnt work..
Old Aug 3, 2005 | 08:14 PM
MaxxAddict's Avatar
hmmm, interesting. btw, what's a solder joint? (newbie talkin here). Is it the joint that connects the clock to the power wire???
MaximaSpd85's Avatar
the power went out, sorta like in a weather storm!!
Old Aug 3, 2005 | 09:27 PM
MystA RavE's Avatar
I had the same thing...its a stupid maxima clock problem...unless you want to bother with opening it up and soldering random wires (unless you can actually figure them out which I doubt), you should just buy a new clock and 4get about it as I did
Old Aug 3, 2005 | 09:38 PM
G4nismo's Avatar
while ur checkin the clock, cut the red wire w/ a blue tracer if u haven't done so already
Old Aug 3, 2005 | 09:41 PM
wut does that do?
Old Aug 4, 2005 | 06:24 AM
njmodi's Avatar
Originally Posted by MaximaSpd85
wut does that do?
I believe that will make your clock "bright" all the time - it won't dim with the headlights or brightness control dial.
Old Aug 4, 2005 | 06:25 AM
njmodi's Avatar
Sort of. In your case the power wire is part of the harness plug, which plugs into the harness connector at the back of the clock. Perhaps on of the pins on the connector - that is soldered onto the circuit board, is cracked/intermittent.
The quickest fix is to replace the clock. You can probably pick up a cheap replacement off Ebay or try posting in the 4th Gen classifieds forum.
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
