Drivers's door thunks when shut
Old Aug 5, 2005 | 11:41 AM
sky jumper
I checked the stickies and TSBs but didn't find anything on this. a split second after I shut my driver's door, and audible low-pitch double "thunk-thunk" can be heard. anyone know what this is??? I'd rather not tear open my door panel if I can avoid it.
Old Aug 5, 2005 | 11:45 AM
86maxima96's Avatar
I Broke OT
it's after you shut it? my door used to not shut quite right because I left it hanging open for a long time while I was checkin the codes/fuses in there. I just tightened the hinge part and it was all better.
Old Aug 5, 2005 | 11:46 AM
sky jumper
the noise is after the door is completely shut. it seems to come from near the outside handle. almost sounds like a large hunk of iron swinging back and forth inside the door.
Old Aug 5, 2005 | 12:04 PM
86maxima96's Avatar
I Broke OT
hmm. does your window work fine?
Old Aug 5, 2005 | 12:20 PM
DennisMik's Avatar
maybe the window channel itself is loose. you'll just have to take off the door panel and look.
Old Aug 5, 2005 | 01:56 PM
Sounbwoy's Avatar
taking off the door panel is very easy. There's either a stickie or if you look thru and find a post on removing and mounting a mirror assembly, it'll be there...
Old Aug 5, 2005 | 06:36 PM
MystA RavE's Avatar
maybe its the locking mechanism
Old Aug 5, 2005 | 09:58 PM
ryant35's Avatar
If its sounds like it's inside, there really isn't any other option. Take it apart. I've only had owned Max's for a couple of months and it only takes me 5 minutes to take off the door panel.
DJLAX152
May 4, 2021 11:46 AM
gustavison
Oct 4, 2015 06:50 PM
95naSTA
Sep 21, 2015 06:50 PM
EdRomo86
Sep 12, 2015 07:49 PM
