just installed sprints by myself
Old May 23, 2001 | 02:39 PM
nismo2020's Avatar
Needs non-Maxima Friends
i swapped out the pro kit for the sprints. took me about 4.5 hours using a manual spring compressor. i never installed springs before. fairly easy. the ride is the same as the pro kit just a shade tighter. the front is defitnetly lower but the back looks the same as far as ride height goes. hopefully they will settle more. i want no wheel gap at all. anyway my max looks better now because the front isnt higher than the back. the only problem was on the front i couldnt get the brake line little metal u shaped holder to go back on. anyboby know how to? will post new pics soon.
Old May 23, 2001 | 02:45 PM
nixima's Avatar
I had to use a hammer to get that u-shaped clip to the brake line holder.
Old May 23, 2001 | 03:15 PM
NickStam's Avatar
Installing springs is easy Right?
Old May 23, 2001 | 06:13 PM
emax02's Avatar
My rear is the same height as when I had my Eibachs too, rather dissapointing but the front is perfect just enough room to barely get 2 fingers in. My rear springs never really settled down at all though, atleast in the 600 miles I have had them on.
Old May 23, 2001 | 06:17 PM
Sprint's Avatar
did you cut the bumpstops?
Old May 23, 2001 | 09:14 PM
Shadow's Avatar
You don't want to drive a Maxima with no wheel gap, there would be absolutely no travel left. My ground controls are dropped as low as possible up front, and there is still maybe 1 finger of gap. It sits about 1.5" above the bumpstop. The ride is very bouncy, so if there were no gap, there would be no travel. What I am going to do pretty soon is to buy custom springs for the front. The same rate, but shorter springs. That way, I can crank them up a little for daily driving, and slam it down for shows. I want to bust tuck at shows. The back already can do it when dropped all the way, the edge of my 19" rim is even with the fender, but the front always has gap.
Old May 24, 2001 | 05:02 AM
nismo2020's Avatar
nixima- thanx i will try that
sprintmax- i did not cut any bump stops. they might have been cut when i had the pro kit installed last year.
nickstam- yeah putting springs in is not hard at all
Old May 24, 2001 | 08:52 AM
GTRBlkMax97's Avatar
Where are the bumpstops does anyone have a pic of them? Also what would it do if you do not cut them?
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
