TPS closed
Old Aug 7, 2005 | 10:56 AM
udienow's Avatar
TPS closed
My ses light went on so i hooked it up to a scanner and got the following codes. p0510, Throttle Position sensor closed. and 2x of p0325, Knock sensor. Before i got these codes my car would idle sometimes at 1k rmps, and other time it would idle normally, in park my car sometimes idles as high as 1500 to 2000rpm, then after a bit it just goes back down and normal again. I looked in the stickies and found no real explanation on how to fix the closed TPS. Where is it and how can i fix it, and how much would this cost... I am getting a new KS today so I would also want to buy whatever else i need to fix this p0510 code. Thanks for any help from anyony in advance.
Matt
Old Aug 7, 2005 | 01:14 PM
njmodi's Avatar
Do I get a tax break?
You probably need to replace the TPS. Its not a cheap sensor - so start shopping the 4th gen classifieds.. I know there were a few available there.
Old Aug 7, 2005 | 02:36 PM
BigLou93SE's Avatar
getting it from a dealership will run you more than $150 (low estimate since jrnissanparts.com, which sold cheaper than retail parts but doesn't anymore was selling them for $162...)
Old Aug 7, 2005 | 03:12 PM
96sleepergle's Avatar
you can try adjusting the sensor first before replacing it you will need a feeler gauge and a ohm meter for this procedure the sensor in combined with throttle positon sensor and a closed throttle swith thats why there are 2 wire harnesses i would gladly send you the procedures yes they are expensive nissan dealer part a must dont look for a used one
Old Aug 7, 2005 | 03:28 PM
-Sin-'s Avatar
Autozone TPS 60 - wells brand, pinnicale (cheapest OEM I could find and got) <100 shipped and if you get a new one they changed the procedure for adjustment.
Old Aug 7, 2005 | 06:37 PM
udienow's Avatar
Can i have some more info on how to fix this TPS closed problem? Where is it... and how hard is it to change it?
Old Aug 7, 2005 | 06:49 PM
bhmax16's Avatar
I too would like to know where the TPS is. I need to disconnect it before I can try readjusting my idle since it's currently quite high and a little dippy at times
Old Aug 7, 2005 | 07:39 PM
BigLou93SE's Avatar
Look in the HOW TO faq's. There is a link for "troubleshooting TPS problems"
Old Aug 7, 2005 | 08:59 PM
udienow's Avatar
What ya mean they changed? Is this thing hard to install... gonne buy one tmrw... and is it ok to get the autozone one for 60 bucks or should i get the OEM one from stealer...?
Old Aug 8, 2005 | 05:05 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
there are 2 types of tps sensors. 1 is for standard transmission and 1 is for automatic transmissions. the auto trans is about $150 and the standard is about $60
Old Aug 8, 2005 | 05:22 AM
-Sin-'s Avatar
The process for adjusting has changed based on NTB99-053b, the new process involves using the closed throttle swith to adjust instead of using the 500~4000ohm rule, and the price I got for the OEM version is only 20 dollars more so I just picked that up. Never used the autozone so i can't really comment on that one, but the TPS, from what I discover and experienced, is very important, almost got hit by a semi due to hesitation, so I got OEM.
Old Aug 8, 2005 | 05:26 AM
-Sin-'s Avatar
Not true, they are the same for all. Mine is an auto, 60 bucks wells and 87.40 for OEM at Pinnacle nissan web site.
Old Aug 8, 2005 | 08:31 AM
killcrap's Avatar
1995 - Standard Trans - 2262031U01 $47.34
1995 - Automatic Trans - 2262031U10 $145.48
1996 - 2262031U15 $145.48
1997-1999 - 226204M510 $106.04
95-96 had different part numbers
97-99 have the same.
Old Aug 8, 2005 | 08:44 AM
-Sin-'s Avatar
Yeah, I was looking at 97-99, I have a 98, should have clarified...
Old Aug 8, 2005 | 12:09 PM
udienow's Avatar
Ok i ordered new KS and TPS from pinnacle.. now i know how to go about installing KS, what about the TPS, anyone got any info on properly installing and adjusting new TPS?
Old Aug 8, 2005 | 12:30 PM
-Sin-'s Avatar
I have it. Send me a PM with your email and I'll send it to you, I don't have the authority to attach files.
Old Aug 8, 2005 | 03:33 PM
MaximaInCT203's Avatar
schemes on chicks in his max.
i would absolutely recommed replacing the Knock Sensor just for the simple fact that when it goes, it sends numerous other "false" signals to the ecu such as crankshaft position sensor errors, MAF, and TPS
Old Aug 9, 2005 | 05:38 AM
killcrap's Avatar
so thats what a knock sensor does. i always thought the ecm uses it to advance the timing until the knock sensor produces the voltage to trigger the ecm to retard the timing a tad, and if it senses detonation, it would retard the timing. but now with the new information you just provided, anytime i get a cps or maf, or TPS failure i'll just replace the KS.
thanks MaximaInCT203! Your the BEST
Old Aug 9, 2005 | 06:11 AM
-Sin-'s Avatar
Hint of sarcasm, I hope...
litch
123
Jan 4, 2024 07:01 PM
mkaresh
Mar 12, 2018 06:48 PM
Garrettz459
Sep 28, 2015 02:50 PM
Noela
Sep 26, 2015 08:22 AM
Vequity
Sep 10, 2015 05:26 AM
