VQ engine question.
Old Aug 9, 2005 | 04:36 AM
HoldTight's Avatar
VQ engine question.
I have 1998 4th gen. The question i have is where do I find out if my engine is a VQ35DE or a VQ30DE.
I apoligize now for such a noob question. It won't always be that way.
HoldTight...
Old Aug 9, 2005 | 04:41 AM
sunten1
VQ30DE
10 letters
Old Aug 9, 2005 | 05:26 AM
Stephen Max's Avatar
The VQ35 didn't come in Maximas until the 2002 model year, so unless somebody did a swap, you have a VQ30DE.
You can verify this yourself by looking for "VQ30" stamped on the engine block near the rear of the right bank cylinder head, in the vicinity of the fuel pressure regulator.
Old Aug 9, 2005 | 07:19 AM
MaxKlinger's Avatar
Unless your car has had some radical modifications, you have a VQ30DE. Your engine and transmission type should be stamped on a plate riveted to the firewall. The plastic shroud over the valve cover should also say "V6 3000" which means it is a 3,000 cc (3.0L) motor - this is what the "30" in VQ30DE stands for.
Take a look at these reference pages on Fresh Alloy to learn more about wat Nissan engine designations mean.
http://www.freshalloy.com/site/featu...me_codes.shtml
http://www.freshalloy.com/site/featu...nes/home.shtml
Old Aug 9, 2005 | 08:23 AM
sdoherty_tjm's Avatar
maxklinger thats not how you find the displacement of an engine in cc. it is a more specific measurement than cubic inches, in which we have 188 cu. in.
Engine GXE SE GLE
Engine Type VQ30DE DOHC V6
Displacement 3.0 liters (2960cc)
Horsepower (SAE net) 190 hp @ 5600 rpm
Torque (SAE net) 205 ft-lbs @ 4000 rpm
Induction System Sequential multi-point fuel injection with variable induction
Compression ratio 10:1
Valvetrain 4 valves/cylinder
https://maxima.org/modules.php?name=specs_1995
Old Aug 9, 2005 | 12:23 PM
MaxKlinger's Avatar
You're right, it is actually slightly less than three liters or 3,000 cc. If you actually calculate the displacement from the bore (93mm) and stroke (73.3mm), it comes out to 2987.5cc. I was just noting the plastic shroud over the valve cover, which does in fact say "V6 3000" inferring that is roughly 3,000cc or 3.0L of displacement.
Old Aug 9, 2005 | 12:27 PM
More like 182 cu. in.
Old Aug 9, 2005 | 12:29 PM
NmexMAX's Avatar
dot dot dot ...
2988 cm^3 for arguments sake.
Old Aug 9, 2005 | 12:31 PM
NmexMAX's Avatar
dot dot dot ...
Sdoheryt, don;t you remember me correcting myself from the 188 --> 182? You''re young, you should have a better memory than I do.
But, since they're Maximas, they typically go more for metric measurments, this has also gone into effect with the Amercian car makers as well... 4.6, 5.7, 6.0L etc ...
Old Aug 9, 2005 | 12:35 PM
Flava_24/7's Avatar
Boosted Panda
HoldTight...
95-99, VQ30 DEYou would definalty know if you had the 3.5
It would be due to a swap, the seller would have informed you and also charged you for it as well.
Old Aug 9, 2005 | 12:39 PM
Jeff92se's Avatar
I'm needing a caw
Please don't question him. He's been an import mechanic for over 10 years.
Old Aug 9, 2005 | 12:59 PM
NmexMAX's Avatar
dot dot dot ...
Straight out of kindergarden ...
My previous car had 188 cu/in dia. : 3.1L Pontiac ..
Old Aug 9, 2005 | 04:57 PM
HoldTight's Avatar
Thanks all for educating me on my car. I hope to return the favor.
Holdtight...
James92SE
142
Jan 2, 2024 09:23 AM
Socalstillen
Sep 20, 2015 11:46 PM
pears
Sep 18, 2015 05:25 AM
seesole
Sep 14, 2015 12:38 PM
conansriver
Sep 11, 2015 10:26 AM
