Will failing ign. coils act up in neutral?
Old Aug 18, 2005 | 11:55 AM
Kehops's Avatar
Just trying to figure out if I've got a busted ignition coil or not. When in neutral, I can rev up the car no problem. Only when in gear, when my gas pedal is at the exact same spot in ANY gear, it'll bog down a little until I pass that point in the pedal, then it's pretty much smooth sailing until the next point. There's 2 precise points in the pedal where the car will bog for a second, roughly 1/4 pressed and 3/4 pressed. I know it sounds weird. Could this also be my TPS?
Thanks guys
Old Aug 18, 2005 | 12:36 PM
Kehops's Avatar
Someone's gotta be able to help me, please.
Old Aug 18, 2005 | 12:43 PM
njmodi's Avatar
Do I get a tax break?
No codes right? (Check even if the CEL is off).
Stephen Max's Avatar
Yes, it could be a bad spot in the TPS. If you have a voltmeter you can check TPS voltage to see if it goes haywire at that particular angle.
Old Aug 18, 2005 | 12:50 PM
Kehops's Avatar
Well I have CEL but only 0505 coming from it.
Old Aug 18, 2005 | 02:43 PM
alpimax99's Avatar
0505
No Failure Recorded/Detected
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
howardis
Dec 11, 2019 06:10 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
