where to put foglights? and how?
Old Aug 21, 2005 | 06:00 PM
mendon99's Avatar
tastey wheat
hey guys, just bought some fog lights, and i want to know where anyone thinks the best location for them is... i mean like in the middle, or as far apart as possible (where the stock's would go)? or does it even matter?
also, how are you guys (with aftermarket fogs) attaching the brackets on there? just screwing them in thru the bumper? i've got some ideas im throwing around in my head, but i just want to see what you all are doing first.
thanks for your input.
Old Aug 21, 2005 | 10:01 PM
shmad's Avatar
there are existing holes in the spots for the stock foglights. i used those holes for mounting my fogs. i used a relay, so whenever my corners are on my fogs are on.
Old Aug 21, 2005 | 10:29 PM
1996blackmax's Avatar
I was going to get some and just put them in the lower opening on the bumper, in the corners.
Old Aug 22, 2005 | 06:41 AM
mendon99's Avatar
tastey wheat
you mean where teh stock's would go on the side? the fogs i bought mount from the top or the bottom only.. this is why im having trouble kinda
Old Aug 22, 2005 | 06:51 AM
Majestic's Avatar
Yahhhhhhh
Seems like the best way. That's the way i've always done it.
Old Aug 22, 2005 | 08:19 AM
shmad's Avatar
it mounts from the top. there are already holes there so use them. i did run into a slight problem. those holes dont sit even b/c there is a metal plate near one of the holes. i just dremeled a small piece off of it. although u could probably use a couple of washers to make the lights even and it should work just as good.
Old Aug 22, 2005 | 08:24 AM
9maxima5's Avatar
On the 95-96 we dont have cut outs on the bumper, I would like to put some round like 3" in ,but how would I cut the bumper and has anyone done this? Also the bumper is at an angle so how difficult would it be to keep them level?
Old Aug 22, 2005 | 08:27 AM
shmad's Avatar
i have a 96 gxe. when i bought mine i had a large crack in the bumper so i put a 96SE bumper on. ive read that all u need to do is cut the hole out
Old Aug 22, 2005 | 09:03 AM
mendon99's Avatar
tastey wheat
Update
alright guys, had time to install them this morning. tell me whatcha think:
and off
these things are bright, i can't wait to see them at night.. ill have night shots later
btw, i ended up installing them from the bottom. works good, just bolted them up from under there..
man, my headlight housings are foggy.
Old Aug 22, 2005 | 09:05 AM
9maxima5's Avatar
mendon99 those look good. Anyone with a 95-96 that had to have the hole cut out have any pics?
mendon99's Avatar
tastey wheat
OH btw, if anyone wants 1 drivers side stock SE fog light, let me know, ill sell.. also i have the brackets for both (no bolts) if anyone needs those to, whatever
Old Aug 22, 2005 | 01:45 PM
9maxima5's Avatar
bump for pics of a 95-96 with the wholes cut out for the fogs.
Old Aug 22, 2005 | 08:12 PM
9maxima5's Avatar
bump bump..
Old Aug 23, 2005 | 10:17 AM
maximus_96's Avatar
i want to know too. i have a 96 gle and need to cut the hole for the fog. i was thinking of cutting out the plastic, then fit a gutter guard mesh behind it to match the rest of the mesh. and mount a 3" round light there. anybody have projector fog lights? i don't see any on ebay at 3"...
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
220k+ A32
Sep 23, 2015 03:38 PM
Hdnseek
Sep 9, 2015 05:55 AM
