Vehicle Speed Sensor Removal
Old Aug 23, 2005 | 06:06 PM
Xservice0183's Avatar
How to: Vehicle Speed Sensor Removal - Currently Attempting, Need Help
I received an Error Code coming from this sensor, i've finally decided to attack this problem. I located the sensor, believe it or not, i'm skinny and long enough to reach it without removing anything. So i've removed the bolt, the electric connection and now i'm struggling to remove the actual sensor. Would someone be so kind as to explain how to remove it, is there something i'm doing wrong. The manual doesn't say much other than;
Disconnect electric connector
Remove hold down bolt and clamp
Remove Sensor.
I think i'm having a hard time removing the clamp, how do I disengage this clamp and where is it?
Old Aug 23, 2005 | 07:51 PM
Can anyone help me out please.
Old Aug 23, 2005 | 08:01 PM
Jepht20's Avatar
Custom User Title...
i had trouble when i did mine too but what got it was using a thin flat head screw driver and prying it out. it pretty much pops up and out...goodluck
Old Aug 23, 2005 | 08:04 PM
I don't know if it's bad or not, so i don't want to break it. Did yours come out in tact? Will my car start for school tomorrow without it - in case it cracks?
Old Aug 23, 2005 | 08:24 PM
It's out. It was generating everything except .5 Volts leading me to believe it's Bad. Even 1.x~ was coming out. I hope i was using my dad's meter Correctly, it was at AC 2Volt Setting, and I was connecting the 2 leads from it, to the leads which the electric connector was on Sensor.
Thanks Jepht20
Old Aug 23, 2005 | 08:53 PM
turbo
Slightly OT: Where is the sensor located? My car is throwing the identical code causing the cruise not to work sometimes.
Old Aug 23, 2005 | 08:56 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
here is an old pic I have:
if you are standing on the drivers side fender looking straight down, its on the top of the transmission twords the back, and its held in by just that one bolt, unscrew it and pull straight up, but be ready to catch some gear oil that will spill out.
Old Aug 23, 2005 | 08:59 PM
turbo
Sweet Thanks!
Old Aug 23, 2005 | 09:18 PM
So my car runs without it, since I took it out, and it started up, right?
Old Aug 23, 2005 | 09:26 PM
Sorry for draggin this thread out so far. I'm not sure if i used my meter correctly
See Pic:
To freshen your memory, the Manual says .5 Volts AC, so referring to the meter, first button is pressed and then the exact same configuration as shown in the pic, correct? I Tried it both ways, never pressed the Ohms - Last button (my pops warned me against doing so), but I tried just about every other combination and never received a steady .5, it went from .001 - .9## sometimes a 1.###. So if that's the case, then the sensor needs to be replaced?
Old Aug 23, 2005 | 09:43 PM
Vlasic's Avatar
im not sure how to use the volt meter to test it, but did you say that you started your car while it was out? i dont think thats a good idea since you would basically be running your car with a hole in the transmission.
Old Aug 24, 2005 | 06:08 AM
Geerhed's Avatar
Moved on to BMW's :(
I agree with Vlasic. Don't run the car without the speed sensor installed. That section of the tranny probably isn't pressurized, but you'll have transmission fluid sloshing out, all over your steering rack, firewall, and Y-pipe. Fire hazard, etc.
Re-install the speed sensor, get a new one ($18.59 at Rockauto.com) and try that. I don't advocate "shotgun troubleshooting" (replacing of a part in hope that fixes the problem) but it's cheap enough in this case. From what you've said about voltages, and a few suspect readings, the speed sensor probably IS the problem, but if not at least you'll have a spare.
The speed sensor on my 90 SE Auto is ~$80 so at $18.59 consider yourself lucky!
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
