Anyone with a 97 max using a 95 ecu? Any CEL??
Old Aug 26, 2005 | 01:41 AM
Nismo's Avatar
Just wondering if anyone here has a 97 5speed and is using an ecu from a 95 5speed. If so , any CELs?
Old Aug 26, 2005 | 05:08 AM
laylow1988's Avatar
yes i have cells but i'm using a 95 auto in a 97 5 speed
Old Aug 26, 2005 | 08:24 AM
nismos14's Avatar
§è~® f®ÈÄk
I've got a '96 ts ecu in my 97 and I had the 0707 code. With the '95 ecu you MAY or MAY NOT get more codes, it depends on the car and what the ecu is tuned for. There are many different versions of the ecu and CEL's are hit or miss with them.
Old Aug 26, 2005 | 01:02 PM
Nismo's Avatar
Thanks guys, Yep I also get the 0707 rear o2 sensor code which im trying to get rid of with an o2 simulator. I think Ill try the simulator now and get a 97 5speed ecu soon just to be shure since I got to pass smog in a couple months.
Old Aug 26, 2005 | 01:54 PM
mitch33x's Avatar
I'll be putting in a 96 MT JWT ECU in my 97 MT within next week or two or so.....after i pass NJ inspection.
Where do you get an o2 simulator?
Old Aug 26, 2005 | 03:00 PM
nismos14's Avatar
§è~® f®ÈÄk
put the simulator on before u put the ecu in
Old Aug 27, 2005 | 12:42 AM
Nismo's Avatar
Im going to put the simulator on in the morning. I got the simulator from here http://www.o2sim.com/
Old Aug 27, 2005 | 08:08 AM
Toolrocks's Avatar
Here's a fix. I don't know if the O2 simulator will work - please inform us if it does but, the 95/96 use a 3 wire O2 sensor while the 97+ use a 4 wire O2 sensor. I think the pin out from the ECU is different and that's why I question if a simulator will do the trick since the signal wires may be going to the wrong ECU pin location.
http://forums.maxima.org/showthread....44#post3390144
Old Aug 27, 2005 | 11:03 AM
Nismo's Avatar
I see, so you think if I simply just get a 97 ecu then the rear o2 code will simply go away? I might just do that then.
Old Aug 28, 2005 | 05:12 AM
Toolrocks's Avatar
Nismo, assuming your rear O2 sensor and harness aren't bad, putting a 97 ECU back into the car will eliminate the code. I don't know if your 95 ECU is re-programmed but the only way to have an upgraded ECU is to use the 95/96 model year which usually causes the "rear heated O2 sensor" CEL in 97+ cars. The link in my previous thread really explains it if you haven't checked it out yet.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
220k+ A32
Sep 22, 2015 03:08 PM
JoshG
51
Sep 21, 2015 10:41 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 10, 2015 09:35 PM
