Oxygen Sensor
Old Aug 26, 2005 | 02:22 PM
edward3956's Avatar
Oxygen Sensor
what is the typical lifespan of an oxygen sensor?
just replaced original os about two years ago and now i've got the check engine light on again, i'm assuming its the sensor again as it was before.
Old Aug 26, 2005 | 02:24 PM
mitch33x's Avatar
dont assume the code is for the o2, it could be for something else. Check the code(s)
THT's Avatar
THT
Throbbing member
60-70K is when all three of mine went. Check the codes before you assume what the problem is.
Old Aug 26, 2005 | 02:26 PM
s600ergy's Avatar
oh my god another victim of o2 problem, good luck
Old Aug 26, 2005 | 02:29 PM
edward3956's Avatar
codes?
do i need a specific code reader to find out. if yes where do i get one?
thanks
Old Aug 26, 2005 | 02:54 PM
THT's Avatar
THT
Throbbing member
Check the stickies for how to get the codes. Or, you can take the car to Autozone, Advanced Auto, etc. and they'll use an OBDII scanner to read them for free.
Old Aug 27, 2005 | 01:59 PM
Max Atlanta's Avatar
My Max has 171,500 on the clock and so far only one o2 has died. Go get one of those cheapy OBD readers and check the codes. That will tell you the exact reason for the code....and you can clear the out the light also when you are finished.
Old Aug 27, 2005 | 02:14 PM
PLUMMAXSE's Avatar
Go by one of the auto parts stores that will read the code for free. You need to make sure it is an O2 sensor!!
Old Aug 29, 2005 | 01:07 PM
naps96's Avatar
'97, 189,950.. Mines still ticking Knock on wood!
Old Aug 29, 2005 | 01:31 PM
Jatan's Avatar
Also see how your gas mileage is doing. If it's low and you have a lot of miles, then the O2s are worn and you'll see improved gas mileage with new ones
I was getting 15-18MPG and now I'm at 20-23MPG with new ones in the front
Old Aug 29, 2005 | 01:49 PM
maxultra's Avatar
Uhh ohh. I got one of these codes the other day. Wish me luck.
WES
Old Aug 29, 2005 | 01:52 PM
dual's Avatar
I just had the second one go back up front. 99k miles.
A weeee bit OT, but is there anyone reading this that could help me? I'm trying to post a new topic, and it keeps telling me I am unable to. I've emailed the typical admins and I get a canned response (none of which includes that something is messed up). I've emailed specific moderators with no response.
Old Aug 29, 2005 | 04:53 PM
nfafan's Avatar
Forget Advanced Auto, they used to back in the day when they were Western Auto, the AA folks don't rent tools, check codes, or do much of anything except the in-car alternator tests.
As for the OBD2 scan tool, the $90.00 Equus tool at Wally World will read codes and re-set ECU lights, good enough.
Had 3 O2 sensors fail w/in 5 year. Nissan sez they could fail due to bad gas!
As for the flaky Nissan O2 sensors, I've had a new one fail w/in weeks of replacement - the next replacement was then done for free.
And new Maximas can have up to 4 O2 sensors... 4 times the pleasure of helping to pay for your Nissan dealers mansion in the suburbs.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
