Losing Clutch fluid?
Old Aug 27, 2005 | 11:46 AM
gtmuggs's Avatar
Does anyone know what maybe the possible cause of my car losing clutch fluid i cant detect any leaks but this cant be good!!!!!!
Old Aug 27, 2005 | 11:50 AM
Bobo's Avatar
More often than not, I suspect it would relate to a slave cylinder that requires replacing.
Old Aug 27, 2005 | 11:51 AM
gtmuggs's Avatar
Is that hard to replace and what does it cost
Old Aug 27, 2005 | 12:25 PM
crazy97's Avatar
I had this happen to me, I was losing a lot of fluid. Turns out there was a 'wet' hose located under the air scoop, a rubber hose that plugs into the tranny. It's about 10 inches long. I bought a new one at the stealer $50. Put it on and the leak is GONE! I need to bleed the line some more but I definitely found the cause.
Edit- This was 2 months ago and no more leaks!
http://forums.maxima.org/showthread.php?t=410038
Old Aug 27, 2005 | 05:13 PM
tavarish's Avatar
fwd gone rwd cr00
well, mine is leaking a little bit, but I think that's because I didn't tighten the slave cylinder as well as I could have, and i'm just lazy. clean all the cables, refill the reservoir with fluid, then looks for leaks.
Old Aug 27, 2005 | 05:33 PM
Wetballoon's Avatar
Possibly the rubber hoses that run to the slave cylinder (there are two of them), I changed my slave and that wasn't the problem. Bought the hoses but I have been too lazy to put them on. There was a thread on this 6 or 8 months ago.
Old Aug 27, 2005 | 06:33 PM
Nismo's Avatar
check under the master cyl. Is it wet?
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
gigabyte
Jan 6, 2017 06:05 PM
Need help
23
Oct 2, 2015 08:56 AM
