knock sensor dead but no ghost code or obdii problems
Old Aug 30, 2005 | 08:37 PM
kasemodz's Avatar
ok I checked continuity on my knock sensor but I didnt get any code from ecu. Ecu thinks everything is fine. Also the obdii says everything is fine. Is this possible? When I am at stopped but in drive, I heard ddadadadad sound. Is that related to knock sensor?
Old Aug 30, 2005 | 10:00 PM
s0ber's Avatar
dadadadadadada
Old Aug 30, 2005 | 10:31 PM
99Automagic
Originally Posted by s0ber
dadadadadadada
The knock sensor makes no noise my friend. You're fine.
Old Aug 30, 2005 | 10:36 PM
goldtooth's Avatar
Isnt that the "knocking" he heard and he is asking if it is related to the knock sensor?
Old Aug 30, 2005 | 10:46 PM
99Automagic
I'm willing to bet his knock sensor is fine, and if he measured the resistance, he measured it wrong.
Old Aug 31, 2005 | 07:15 AM
s0ber's Avatar
If at idle he's hearing some dadadadadadadada that aint pinging...
Old Aug 31, 2005 | 08:23 AM
99Automagic
Yup, that's my guess.
dadadadadadadadada.......
Old Aug 31, 2005 | 10:02 AM
kasemodz's Avatar
so there is something wrong with my knock sensor?
Old Aug 31, 2005 | 10:03 AM
s0ber's Avatar
doubt it, can you check where the dadadadadadad is coming from
Old Aug 31, 2005 | 01:36 PM
kasemodz's Avatar
well u c i read this (http://forums.maxima.org/showpost.ph...3&postcount=41) and decided to test continuity check on my knock sensor. There was nothing. i tried other multimeters and still the same problem. I know for sure that I ahve the right cable, because I traced the cable and from this link.
http://www.motorvate.ca/mvp.php/507&...E8nwiQGcgqG3Dg
I traced that back. I decided to do a 470k bypass from the first link. Immidiately when I started the car I felt a different sound of acceleration, much different. Now my gears shift closer to 3000 rpm rather than 4000 rpm. How long does this 470k bypass work? I'm testing it to see if there is an increase in my fuel mileage.
Old Aug 31, 2005 | 07:17 PM
kasemodz's Avatar
ok i installed the resistor and now the pickup is better i think. I dunno if its psychological or wut. How long should I wait before I get a new sensor?
Old Aug 31, 2005 | 07:31 PM
nismos14's Avatar
§è~® f®ÈÄk
It's probably placebo affect. You THINK something is wrong, so you're mind makes you think that now that you have the resistor in it is actually working properly. The resistor wouldn't affect where you're car shifts at. Also this DADADADA is not going to be enough for us to figure out wtf is wrong with you're car. Try explaining in better detail and maybe then we can help.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
intimidator
Sep 5, 2015 07:23 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
