fans keep running
fans keep running
I tried to change the front o2 sensor, disconnected the sensor, tried to get it out with no luck put it all back togeather and now the fans run when I start the car. Looked but didn't find any loose wires. Trouble code came back front sensor again. Will have a local garage change it but why are my fans running when I start it cold now?
Originally Posted by cpt
And thats why I love this forum. You are right, I just checked it out. I thought I messed something up. Where else can you get an answer in 5 minutes!
.....so quick to take it to a shop before checking yourself will get you owned by the shop. they probably would of charged you for what ever they wanted and all they would've done was cut your air condition off..
hi guys, im sorry but i have to post in here cause im not allowed to make a new thread do not know why but....
any way i have a problem with my max 97, it gets overheated i changed the thrmo last week but it is still overheating, the overheating happens when i accelerate too much, that is when the needle goes up and when i release the gaz pedal it starts to go down but it does not reach the desired level which i used to have (the line right over the C line). can any one help or advice of a good site where i can find diagnostics
I am sorry again but this is what I have on my display:
Posting Rules
You may not post new threads
You may post replies
You may not post attachments
You may edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Posting Rules
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
RWCreative
Sep 21, 2015 11:01 AM
