A sound while breaking
Old Oct 11, 2000 | 01:31 PM
Hi, guys!
I just bought a 1995 GXE Maxima. Everything is great so far, but when I break (on a medium to high speed), I started hearing a pretty loud, thin noise (from breaks, I guess). The car breaks normally. On the dealership where I bought it, they said they put new breaks. Could this noise be just because the breaks are new (and not original), and might dissapear later on? Should I just wait for a while, before I invest again in just recently bought car?
Thanks a lot to everyone.
Regards,
Eugene.
Old Oct 11, 2000 | 01:43 PM
maxrules's Avatar
Any noise from the brakes isn't good. My 95 GLE has 95k miles and stops without so much as a squeak. If your dealer put cheap metallic pads on the front, that could be part of your problem. I'd suggest that you go and get a new set of good pads and change 'em again yourself. While you're at it, check the rotors for any damage - if something's been installed wrong from the previous change you could be getting something rubbing on them. Pads are relatively cheap and very easy to swap - do it soon before damage (or more damage) is done. Good luck.
Old Oct 12, 2000 | 07:21 AM
Re: to Doug
Thank you, Doug! I don't think I would be able to tell by myself for sure, whether the pads' position is appropriate. But I will monitor the situation for a week or two, and do something about that. By the way, I called my dealership again, and they confirmed, that they installed new breaks there, and they (breaks) "just need time to adjust" (I'd wish that was true, but I doubt so...).
Eugene.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
