150k!
150k!
I know this isn't odd in the nissan world, but I recently reached 150k on my 1996 5 speed maxima. I cannot believe how great this car still runs. I was curious of any maintance that will have to be done any time soon with this mileage on the vehicle? It runs great, no problems, but is it to many miles to start moddin it? Let me know what should be done, should I replace injectors, have the timing chain adjusted, etc? Any suggestions are highly appreciated. Thanks in advanced.
If it ain't broke, don't fix it!
Do all the visual checks normally done at 60K - exhaust, suspension, CV boots etc.
When was the last time the fluids were changed: power steering flush, radiator flush, brake flush, transmission flush or drain and fill if automatic, transaxle gear oil and clutch fluid replaced if manual.
Fuel filter, air filter, pcv valve?
Clean throttle body, IACV valve, Seafoam through brake booster hose, Chevron Techron in fuel system.
Consider running two applications if AutoRX through crankcase - see www.auto-rx.com
PS check the condition of both belts as well as hoses.
There was a 150K thread a week or so ago. Check that out.
yea. i dont think there are specs to do at 150k. aleast that i know of. since most warrantys max out at 100k. after that they just go by what broken.
doing a 60k isn't too bad of an idea tho.
Originally Posted by SRJesse
yes everything has been maintained such as fluids and belts... I was just curious of anything major as I said either timing chain adjustments, injectors...
thanks for the info...
-matt
Originally Posted by FunLovinMaxima
150k! pretty dang good! i wonder what the highest mileage max on the .org is.
-matt
neilraz
Sep 11, 2015 07:36 PM
BML94GXE
Jul 7, 2004 01:19 PM
