Problems with front brakes after changing rotors and pads...Please Help!
I changed my front rotors and pads about 3 weeks ago and ever since I keep getting a rattle noise when I go over bumps or when I shift into 2nd or 3rd hard. I took the wheels off again last night to see if I had done anything wrong, but I see no problems. It sounds like it is coming from the right side only. The noise doesn't happen when I go over a big bump with my breaks on.
I have heard about shims. Could someone tell me exactly what they are and if they would solve my problem. It is pissing me off because the first time my car is running good and strong, I have to drive around with this embarrassing noise. Please Help!
Thanks,
Brett
Thanks,
Brett
Thats your pads moving slightly and making the noise. You can usually solve this by installing a new shim kit from Nissan. Make sure you use plenty of anti-sieze as lube when you put everything back together. The pads should sit snugly, yet not be very tight. Too loose and you get pad rattle as you have.
This is just an idea, ...When I took apart my front brakes to cure the rattle, I forgot to reinstall the two wire clips that slip into the notches on the pads. I actually had to take everything apart again just to get them in. They keep the pads pressed up against the caliper, away from the rotor. I'll try to find some pics of it.
EDIT: nvm. I don't think that would be the cause. Some people have them on, some don't. But one more thing I forgot to mention. The metal plates that sit behind the pads came loose on mine and were rattling around. Maybe that could be something you could check. It's not the guides that the pads slide back and forth in, it's the plate the caliper piston comes in contact with. Mine came loose, rattles around and actually got bent.
I don't have anything between the caliper piston and the back of the pad. Should I?
03VQMAX
09-25-2015 04:19 PM
MAXSE5SPD
08-23-2015 12:06 PM
RealityCheck
08-05-2015 06:18 AM
