Fuel Pump
Old Sep 8, 2005 | 08:14 AM
mxzmax's Avatar
Fuel Pump
Ok I looked and cant find anything in the faqs on changing a fuel pump so if anybody could so kindly point me int the direction of it or could explain to me how to change it so I can get my god damn car running again!
Old Sep 8, 2005 | 08:17 AM
njmodi's Avatar
Do I get a tax break?
Here's the general idea (I haven't done his myself).
1. Pop out the back seat - there are two plastic tabs on the underside - pull on them and the seat pops out.
2. Remove the fuel pump cover plate
3. Remove old pump, replace with new
4. Replace cover plate
5. Replace rear seat.
You might want to unplug the fuel pump fuse as a precaution - it is in the fuse panel under the steering column.
wikidminds's Avatar
buy a haynes manual.its the best investment u cud make in a manual for ur car.
Old Sep 8, 2005 | 08:19 AM
nismology's Avatar
Yes. Buying a haynes manual will be one of the best purchases you make for your car. Before you tackle this though, be sure to relieve the fuel pressure first. You don't want gas squirting everywhere.
How are you so sure that it's your fuel pump that's keeping your car from running? There are many different possibilities. Have you tried changing the fuel filter?
Old Sep 8, 2005 | 08:30 AM
mxzmax's Avatar
alright i got a new fuel pump relay, I tried the crank sensor because the code came up, code went away when changed it, checked camshaft pos checked other crank sensor, check neutrual safty switch, tps, battery, starter, cables, put in a grounding kit cause the grounds on my motor wernt that good, new ignition switch, the car has spark and some fuel does come out but not the same time as the spark, checked coil packs so if u have any ideas besides the fuel pump let me know. no more codes sense i changed the crank pos
Old Sep 8, 2005 | 08:31 AM
njmodi's Avatar
So what are your exact symptoms? Crank but no start? Any codes at all?
Did you check the fuel pump fuse?
Did you check for fuel pressure after the filter? That would be an easy way to check if the pump is indeed working or not.
Old Sep 8, 2005 | 08:39 AM
mxzmax's Avatar
no more codes since i changed the cranksensor on the passengers side, the fuse is good, I dont have anything to check the pressure
Old Sep 8, 2005 | 08:42 AM
njmodi's Avatar
So the car cranks but doesn't fire...
A fuel pressure guage is not that expensive... you might want to try to get hold of one to make sure the fuel pump is indeed the problem. Fuel pumps aren't cheap.
Old Sep 8, 2005 | 08:43 AM
maxgtr2000's Avatar
KH3 by popular demand
There maybe something in the stickies on a how to, if not, check the members list and look up MardiGrasMax, he has a write up on his home page. Check the fuse before you go to changing that, I've never really heard of them going out but I know it can happen. You just don't want to change it and still have it not start.
Old Sep 8, 2005 | 08:51 AM
mxzmax's Avatar
ya i know i just dont know what else to look for anymore
Old Sep 8, 2005 | 09:03 AM
nismology's Avatar
I vote CPS (POS)...
Old Sep 8, 2005 | 09:08 AM
Chunger's Avatar
My other car is a Hybrid
if you still need it: (pics are not available though)
http://webpages.charter.net/chunger/Walbro.htm
BTW you can listen for the fuel pump to energize the first couple of seconds that the key is on the "on" position... or use the squeeze the fuel line trick to see if there is pressure.
Old Sep 8, 2005 | 10:26 AM
nismology's Avatar
He told me through AIM that he checked for spark and there was no pattern to it. It was just random and erratic. That points to either the crank position sensors or the cam position sensor. He checked the cam sensor and the CPS (REF) and they checked out good. The only thing left is the CPS (POS). This is not a fuel issue. This is a timing issue.
Old Sep 8, 2005 | 10:31 AM
njmodi's Avatar
nismology - you may be right.... he says he replaced on crank sensor and checked the other...
mxzmax:
What code did you have (for crank sensor) and which one POS or REF did you replace?
Old Sep 8, 2005 | 11:09 AM
mxzmax's Avatar
i changed the one on the passenger side of the car and the code was i believe 0407 its gone now since i replaced the sensor
Old Sep 8, 2005 | 11:19 AM
njmodi's Avatar
Well you replaced the right sensor for the 0407 code - CPS REF... i.e. the one on the passenger side near the oil pressure sender...
As Nismology said, it might still be a CPS issue - you might have a faulty CPS POS sensor (the one in the transmission housing).
Old Sep 8, 2005 | 11:30 AM
mxzmax's Avatar
i dunno ill swap it out with my buddys parts car and see what it does
Old Sep 11, 2005 | 08:30 AM
High Altitude's Avatar
Can someone tell me exactly where the CPS is on the transmission housing? Thanks.
Old Sep 14, 2005 | 10:33 AM
mxzmax's Avatar
alright it aint the cps so back 2 the fuel pump i guess
Old Sep 14, 2005 | 10:35 AM
njmodi's Avatar
There is a brand new walbro fuel pump for sale in the F/S forums.. just got listed today... its a great deal - just FYI.
Old Sep 14, 2005 | 12:43 PM
mxzmax's Avatar
cool ill check it out
Old Sep 16, 2005 | 07:08 AM
nismology's Avatar
You buy the fuel pump you'll be wasting your money. Fuel pumps don't go completely bad until way after 200k miles unless you have a bad habit of running the fuel level extremely low for extended periods of time. You said you got intermittent spark with no pattern to it. This is a timing issue. I would use all 3 timing sensors from your friends car, cam position sensor, and both crank position sensors. Transfer those to your car and see if it starts. If it does, remove one at a time and replace it with one of yours to narrow it down. If it doesn't, it might be a compounded problem. But try that for now and get back to us.
jmlee44
Oct 2, 2022 02:13 PM
Miket2006
Mar 1, 2021 03:55 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
