Which NGK spark plugs to get?
Old Sep 16, 2005 | 03:02 PM
stas29's Avatar
I have a 97 maxima with about 80k miles. I went to Advance auto parts and they sell NGK G-power Platinum plug for $3 a piece and NGK Iridium IX Platinum Plug for $7 a piece. My engine shows no misfire codes but I guess it's time to change my spark plugs anyway. I guess I will buy NGK Iridium IX Plugs.
Any ideas?
Old Sep 16, 2005 | 03:04 PM
RA030726's Avatar
I'm nutty for Nissans
the coppers are better overall. just pick them up.
Old Sep 16, 2005 | 03:12 PM
njmodi's Avatar
Do I get a tax break?
Any ideas?
Neither. Either get NGK V-power copper plugs, or NGK Laser platinums. Either of those will work fine. Anything else, you're on your own and are unproven.
Old Sep 16, 2005 | 05:37 PM
Ceasars Chariot's Avatar
Old Maxima Legend
NGK Platinum plugs - PFR5G-11
Old Sep 16, 2005 | 05:43 PM
flthere's Avatar
Would be nice if there are stickies for:
1. Spark plugs
2. Struts
3. Springs
I know that all these are clearly explained in http://maxmods.dyndns.org/index.php but looks like majority of the questioners don't know abt it. I think it's a good idea to have stickies on the above with a link to the maxmods site that'll cut the no. of new threads posted by half
Old Sep 16, 2005 | 06:49 PM
mizmo21's Avatar
platinums will got 60 g's coppers 35 g's
Old Sep 16, 2005 | 06:59 PM
RA030726's Avatar
and plats are $10+ while the coppers are under $2. do the math. plats are junk.
Old Sep 16, 2005 | 07:01 PM
wannaboostbad's Avatar
Put whatever is recommended by nissan.
Old Sep 16, 2005 | 07:57 PM
stas29's Avatar
1995-2001 Maxima and 1992-1994 Maxima SE
* OEM NGK type PFR5G-11 Platinum Spark Plugs
o Description: This model is very highly recommended. They are the type supplied from the dealer. These spark plugs will last 60k miles.
* NGK type BKR5E-11 Copper Spark Plugs
o Description: Very similar to the Platinum plugs above, but cheaper and supposedly provides a colder and more powerful spark. Also will only last 30k miles.
* NGK type BKR6E-11 Copper Spark Plugs
o Description: The exact same plug as above except 1 step colder, only useful in Nitrous or Boosted applications. Colder plugs will provide less horsepower, but will reduce the chance for detonation and will let you run higher levels of boost to compensate. Also will only last 30k miles.
* NGK type BKR7E-11 Copper Spark Plugs
* NGK type BKR5EIX-11 Iridium Spark Plugs
o Description: This is a Iridium type spark plug. It tends to last longer than copper and is useful for boosted and nitrous applications with the right heat range.
Old Sep 17, 2005 | 06:21 AM
njmodi's Avatar
If you are running a stock car (other than exhaust/intake mods), you should use either of these:
The coppers run 2 bucks a piece, the platinums about 8 bucks... take your pick. (The coppers last 30k, plats 60k).
Old Sep 17, 2005 | 07:19 AM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
Any ideas?
If you're looking for spark plugs that will last you 60K miles, go w/ the OEM platinum plugs. If you don't mind changing the plugs every 30K, go w/ the Copper
Old Sep 17, 2005 | 09:49 AM
maximaSE327's Avatar
i also have a 97 w/ lil over 80K... i recently changed mine and got the v-power platinum... theyre a lil more pricy but worth it
Old Sep 17, 2005 | 11:27 AM
maxspeed96's Avatar
I got the copper ones for $1.35 each. For that price, I dont mine changing mine every 30K
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
