Bose stereo buttons broken, can I use a non-bose?
Old Sep 20, 2005 | 11:03 AM
OoTOAoO's Avatar
I have a 95 maxima with a bose stereo system. The lights no longer work (I saw the guide to fix them) and now the buttons sometimes are failing to work (I couldn't find anything on this).
Anyone have any suggestions to fixing it? And if this isn't possible are there different replacement stereos I can buy to replace it?
I hate this b/c I have a 400$ head unit I'd like to use but I think I would need to replace all the speakers? (best buy said this, not sure if it was a sales pitch or whatever)
Please advise!
Thanks!
Josh
Old Sep 20, 2005 | 11:25 AM
njmodi's Avatar
Do I get a tax break?
Check the Audio Section FAQs... the short answer is you can use a non-bose head unit but need an adapter to use the Bose speakers/amp. The adapter is availble from a lot of places (crutchfield for example) for about 50 bucks.
You can also just buy a working used headunit (Bose) and swap it in. They go for 70-120 bucks typically on Ebay and in the classifieds section.
Old Sep 20, 2005 | 11:27 AM
wikidminds's Avatar
ill sell u my bose headunit for $75....pm me if interested
Old Sep 20, 2005 | 11:58 AM
OoTOAoO's Avatar
I actually did read the FAQ and it said you shouldn't do it :/ B/c of the ohm and the equalizer... Any possibility you could link me directly to this adapter I need?
Thanks!
Josh
Old Sep 20, 2005 | 12:06 PM
njmodi's Avatar
http://forums.maxima.org/showpost.ph...9&postcount=25
Old Sep 20, 2005 | 12:08 PM
MaximaSE96's Avatar
Maxima Owner
just find a used on one ebay...i might actually have the one form my 96 u can have
Old Sep 20, 2005 | 12:23 PM
wikidminds's Avatar
tell me if u interstd....$75....
Old Sep 20, 2005 | 01:28 PM
I paid only $20 at my local stereo shop for the adapter. One of many places to find it is crutchfield, or any of your local stereo shops. Don't believe the salesmen, most of them them don't know ****.
Old Sep 20, 2005 | 01:39 PM
OoTOAoO's Avatar
crutchfield.com I take it? And do you happen to know the model you bought?
Thanks!
Josh
Old Sep 20, 2005 | 02:00 PM
Thanks!
Josh
Like I said, I ordered from a local stereo shop. I told them I was installing a Kenwood DDX-8017, and needed the adapter so I wouldn't have to cut the OEM plugs off. Here's a pic of what it looks like. You have to get an adapter with the RCA's in order to keep the audio signal at line level when going with an aftermarket deck. Also, you better make sure your aftermarket deck has both front and rear RCA speaker connects. The wrapper for the adapter is at home. I can get a model number off of it if you want. LMK.
Just to eliminate any confusion... what you see plugs into the OEM plugs. Then I plugged the Kenwood wiring harnesses into the back of the Kenwood deck, and wired it up. The RCA's you see plug directly into the back of the Kenwood deck. Veeeery simple.
Old Sep 20, 2005 | 05:32 PM
95jr6708's Avatar
Please advise!
Thanks!
Josh
\ that is a bose system for you. What i would do is by the 1997 bose unit, works better and it is relatively cheap. Plus you wont have to replace speakers. I think it looks better to. Just my opinion.
Old Sep 20, 2005 | 05:38 PM
^^^^^ Yup 97/98 Bose Deck is the best looking IMO.
Old Sep 20, 2005 | 05:53 PM
OoTOAoO's Avatar
Will it fit in the 95 just the same and plug in the same? Does anyone have any pictures of the ones they are willing to sell?
Old Sep 20, 2005 | 06:37 PM
njmodi's Avatar
Any Bose unit from 95-99 will fit (plugs/harness are exactly the same). I would recommend getting a 99 - all these units fail eventually. The newer the unit you buy, the longer it will last (most likely) before it too stops working properly.
tarun900
19
Dec 20, 2021 06:57 PM
leatherneck
Sep 30, 2015 09:16 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
sliptap
Sep 30, 2015 05:57 AM
