Maxima DEAD
Old Sep 23, 2005 | 01:27 PM
Kevlo911's Avatar
Kevlo for President
Maxima DEAD
I was backing out 2 mornings ago and the car turned off and wont turn back on. Car was running good when it was on.
My SMT wireing is good. Starter keeps turning and turning. I smell fuel. I do not see why or how the crank or cam sensors are bad. If they were, I should/would get a hard start. All my grounds are good. CEL comes on but spits out 0505. No leaks or loose connectors. Nothing has been sucked into the engine. Spark plugs have about 55k on them. Coil packs were perfect the day it happened.
What to do?
Old Sep 23, 2005 | 01:42 PM
ThisMaxIsTight's Avatar
hmmmm I can only think its your fuel pump, but since you smell fuel I dont know ..... what is SMT wiring ? ... take it to a mechanic and ask them to diagnose it...make sure they look at for free and then if they find the problem then have them fix it, if its a good price
Old Sep 23, 2005 | 02:10 PM
njmodi's Avatar
Do I get a tax break?
If the CrankPS or CamshaftPS are bad, the engine may turn over, but it WILL not actually spark. That would explain the raw fuel smell too.
Pull, clean and reseat all 3 sensors and connectors and see if that helps.
Old Sep 23, 2005 | 02:15 PM
Kevlo911's Avatar
Kevlo for President
That is prob the last and only thing I can do. I will have to do it tomorrow because I have no time today. Interesting how I had no hard starts or any probs before this. The car just shut off and wont come back on.
Old Sep 23, 2005 | 02:17 PM
njmodi's Avatar
Sounds good. Try find another max to swap out each sensor one at at time to find the culprit.
Old Sep 23, 2005 | 03:53 PM
nismos14's Avatar
§è~® f®ÈÄk
Did you have you're battery tested?
Old Sep 23, 2005 | 04:26 PM
njmodi's Avatar
The other thing that just came to me (although you mention the smell of fuel), is check that the fuel pump fuse is ok.
Old Sep 24, 2005 | 05:10 AM
Kevlo911's Avatar
Kevlo for President
The OptimaRedtop is fine. The starter keeps turning and does not slow down. I checked the fuses and they all look good.
Old Sep 25, 2005 | 08:42 PM
Nick7455's Avatar
Same thing happened to me Kev...no warning but was the fuel pump...just replaced today with a full tank of gas -_- ... smelled horrible and is hard to do in a apartment complex but all is gravy now...remember to get a new O-ring too....my old one didn't fit .... I should have listened to the FAQ's
Old Sep 25, 2005 | 08:57 PM
2 Da Max's Avatar
im afraid thats going to happen to me one day too. your fuel pump can conk out on you anytime
Thats why YOU SHOULD NOT drive with your fuel tank below that quarter mark for long periods of time, it will burn up your fuel pump. remeber the fuel helps cool downt he fuel pump. and it could go anytime, in a race, on the highway, you never know, thats why you should have at least more the the quarter mark on the gass guage
Old Sep 25, 2005 | 08:58 PM
MDeezy's Avatar
If your a 5speed try to pop the clutch to start the car. I was in similar situation where I couldnt start my car, but all sensors were fine, I was getting gas, spark was strong. Poped the clutch car started up and kept cranking, starter got killed in the process.
What are some of the readings your getting from your sensors? When I was testing mine, I was reading the haynes and it had a different braket for the mitsu sensors or hashin ( I believe thats only on the crank ref )
Old Sep 25, 2005 | 09:18 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
sounds like your flooded, try clear flood mode, if still no start, check to see if you have spark. with a spark tester. if no spark check the ignition circuit.
Battery
Ignition Switch
P/N Switch
Inhibitor Switch
Cam Sensor
Crank Sensors
Ignition Coil
ECM
Old Sep 26, 2005 | 06:59 AM
njmodi's Avatar
Kevlo - any updates on this?
Old Sep 26, 2005 | 01:24 PM
Kevlo911's Avatar
Kevlo for President
Yeah, a few days ago I was let my friend drive my car and she went EXTREMLY slow on her driveway. So everysingle rock/pothole/twig got hit and ran over. Somehow it ripped the Crank REF sensor ground in half. I twisted it back together and it works now, but I need to solder it in so its nice and strong.
Old Sep 26, 2005 | 01:30 PM
njmodi's Avatar
I hope your friend was hot
Glad your car's back on the road... NMex somehow shredded his CPS REF harness recently too...maybe its contagious...
Old Sep 26, 2005 | 01:32 PM
Kevlo911's Avatar
Kevlo for President
Very
Old Sep 26, 2005 | 01:33 PM
njmodi's Avatar
Very
Old Sep 26, 2005 | 01:34 PM
Kevlo911's Avatar
Kevlo for President
Uhhh it is. I might email you my prom pic with her if I am in a good mood after class
Old Sep 26, 2005 | 01:36 PM
njmodi's Avatar
I'm waiting eagerly....
Slamrod
Apr 10, 2016 05:24 PM
Balkins
Feb 1, 2016 12:45 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
