Horrible squealing from the rear.
Old Sep 29, 2005 | 07:32 AM
Akumachan's Avatar
I never narc'd on nobody.
I had the misfortune of transporting my friend and his rather large girlfriend around for awhile, and my sprints didnt do too good holding us all up. Lots of rubbing, and now, i here a really high pitched squealing from the rear anytime the car is in motion. I have ceramic pads, and it sounds somewhat similar to when im just very lightly touching the brakes, but quite a bit louder. Is there a bearing in there that she screwed up? Im kinda pissed, and all she said was, "Its not my problem" anyways... any ideas would be nice.
Old Sep 29, 2005 | 01:51 PM
Akumachan's Avatar
Anyone? BUMP!
Old Sep 29, 2005 | 02:08 PM
Bobo's Avatar
How many miles are on the ceramic pads?
Old Sep 29, 2005 | 02:59 PM
Akumachan's Avatar
less than 20k, I highly doubt its them.
Old Sep 30, 2005 | 07:52 AM
Akumachan's Avatar
Bump for some new thoughts.
Old Sep 30, 2005 | 08:00 AM
wolfeg's Avatar
Lift it up and look. Try to isolate the noise and tell us where it is coming from. Don't give big girls rides.
Old Sep 30, 2005 | 08:05 AM
Akumachan's Avatar
Hard to tell a good friend his girl cant get in, but i think he knows that she doesnt get anymore rides in my car... I'm gonna lift the rear up today and see if i can replicate the noise, and see where its coming from.
Old Sep 30, 2005 | 08:19 AM
wolfeg's Avatar
Sounds like you and your friend need to talk.
Old Sep 30, 2005 | 10:17 AM
Akumachan's Avatar
Yeah, he needs a good talking to...
Old Sep 30, 2005 | 10:25 AM
rocco5446's Avatar
check the pads first
Apply the emergency brake, then release fully. Drive around at a good pace, then check the temperature around the wheel. The rears, since they don't do as much work as the fronts should be cooler than the fronts. If they're hotter, than the pads are rubbing/dragging. If they are rubbing, drive in reverse fairly quickly, then hit the brakes. This will force the rear brakes to be used to help stop the car. Put it back into drive, and see if they still rub. If they do, then your calipers might be seized. After removing the pads, check whether you can turn the rear piston in without much trouble. If it's really hard to turn, the caliper is seized.
Old Oct 1, 2005 | 09:35 AM
ryant35's Avatar
Its hard to believe a fat chick could cause the brakes to squeal. Unless she was a heffer. Although my stepfather is 350lbs and his old Mitsubishi Mirage with 8" non-vented rotors (hard to imagine those brakes stopping his weight)
Anyway the driver side front pads would go to metal and the passager side looked almost new. Not to mention that side axel & tire would go bad offten.
Fat people + cars =
They should all ride scooters in a designated lane.
Move south, we have a very small fat chick ratio.
Old Oct 1, 2005 | 10:07 AM
DennisMik's Avatar
if its the brakes squealing, many times the squeal will go away or change tone if you press lightly on the brakes. of course this is not a fix, just a test.
Old Oct 1, 2005 | 01:45 PM
Akumachan's Avatar
The squealing has actually stopped, but back when it was going, pressing the brakes had no effect on it until i came to a complete stop. either way, the car is happy again, so im not gonna risk messing with it.
Old Oct 1, 2005 | 02:38 PM
MrGone's Avatar
well next time it happens jack up the car and take a look at it, then systematically eliminate what it could be
Old Oct 1, 2005 | 02:49 PM
Akumachan's Avatar
Will do, thanks for opinions everyone.
tsi6001
Oct 3, 2022 10:23 PM
Maximeltman
Advance Paint and Body Work
Sep 10, 2019 10:24 AM
doctorpullit
Apr 5, 2017 12:59 PM
02PearlSE
Oct 7, 2015 02:12 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
