i feel dumb.. but turn signals?
Old Sep 30, 2005 | 10:50 AM
brad kay
Soo this is the first time i've ever had to replace a turn signal bulb on my maxima. My signals on the left side just started going double time so i went to autozone and got both the bulbs for the back and front turn signals. I put both the new ones in and to my chagrin it still blinks fast. I checked the turn sigals fuse and it was fine, swapped in another one just to check, same deal.
So this is a really stupid question but i'm just wondering what else might affect/cause that... turn signals are not my specialty.
Old Sep 30, 2005 | 11:41 AM
FunLovinMaxima's Avatar
From: a charming town in Connecticut first settled in the 1600s
you forgot to change the blinker fluid!!1
No, i'm just kidding. You probably have a short and thats hard to diagnose. Sorry i'm not more helpful.
Old Sep 30, 2005 | 11:54 AM
CalsonicSE's Avatar
The wiring might be loose. Jiggle the wiring near the bulb connector a bit and see if that helps. If it does, set it in place with some tape. That's what I did when my turn signal started working intermittently.
Old Sep 30, 2005 | 12:57 PM
ryant35's Avatar
The bulb doesn't actually supply the flashing. The flash module does. It is located under the driver side dash near the center console. You may need to remove the lower plastic trim.
flasher
Old Sep 30, 2005 | 04:43 PM
nosispower's Avatar
flasher
I clicked on flasher hoping it way something else....
Old Sep 30, 2005 | 07:19 PM
el_muchacho_qc's Avatar
Clean/inspect bulb connector. Check black wire for good continuity to ground. See if other wire (green and black i think) is receiving good voltage when flashing. If no, might have a parasite somewhere.
Old Oct 1, 2005 | 05:29 AM
brad kay
who shot who in the what now?
alright i'm gonna go through everybody's suggested steps today and see if anything fixes it. Thanks guys.
Old Oct 1, 2005 | 08:56 AM
dharrison's Avatar
A parasite, suggesting that something is leeching or hampering power to the bulbs.
Old Oct 1, 2005 | 09:26 AM
99SEL4ME's Avatar
I would suggest just fiddling with the bulbs and make sure they are tight and jiggle the wires like stated above. I've never heard of a flasher going bad. My 93 Max SE, I never once in the 7 years I owned it had to change ANY bulbs except for headlights. Hmmmmm 3rd Gen, WHAT A CAR!!!
Old Oct 1, 2005 | 10:34 AM
ryant35's Avatar
I've replaced them on other cars, and the sure way to know they are bad is if your lights don't flash or flash too quickly. Most other cars the flasher module is blue and on the fuse panel under the dash. I've never seen one like the max. I had to look in my haynes manual to make sure that the autozone part was correct.
But for $20 its a part that you can try & return if it doesn't help.
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
LtLeary
Sep 14, 2015 12:33 PM
minsbang
Sep 11, 2015 08:48 PM
