Q: Fix or sell?
Old Oct 4, 2005 | 10:05 PM
TheMax95's Avatar
Q: Fix or sell?
1996 SE 5speed
120k miles
main things needed to be fixed:
-ball joint/axle(replaced 5x in past)
-coolant leak
-new tires
-many many interior pieces (sunroof, pass seat...)
So....would you fix these problems or would you just sell the car?
Old Oct 4, 2005 | 10:06 PM
2 Da Max's Avatar
you could probably get like 3 or 4 for the car.... its up to u. i would fix it and
Old Oct 4, 2005 | 10:09 PM
NmexMAX's Avatar
dot dot dot ...
I'd fix it, and take care of the ball joint problem .. Odds are if it has died that many times in the past, something else is wrong ..
Where's the coolant leaking from?
New tires? Yeah let's get rid of it because it needs new tires .Why can't I buy a car every time it needs tires ...
86maxima96's Avatar
I Broke OT
do you have the rest of the funds for a new car? try to line something else up before you sell at least. if you fix things yourself, though, it may be worth it to hold onto. if you fix the interior with maybe $300 and do everything yourself, you could add $500 onto the selling price.
hard to say though.
Fr33way™'s Avatar
Wild for Width
Are you having these fixed or doing it yourself?
Really depends on the financial situation but it doesn't seem too bad, with this car you KNOW exactly what is wrong. With a new cheap car you don't . . .
Old Oct 4, 2005 | 10:12 PM
blackmaxx96's Avatar
There's never a day when something's not on sale
It's not worth selling the car for those SMALL problems.....
I need tires on my 18's..... It's still not cranking right all the time..
I just replaced brakes, tranny, clutch, axles, and more...
Now I know what's been replaced, and that nothing else really needs replacing right now...
If you buy another car, you never know what could be wrong with it...
and its not a maxima.....
Old Oct 4, 2005 | 10:15 PM
MDeezy's Avatar
fix it right and be done. What brand axles were you putting in each time?
tires you do it once and be done for a few years (depending).
I need to change axle, axle seal (i believe), control arm, clutch, tranny, drive belts, chain tensioner and guide, and tires. I wont sell, I have a nice corner in the garage building up with parts just waiting for the right weekend.
Old Oct 4, 2005 | 10:29 PM
I like your think deezy
Old Oct 5, 2005 | 07:38 AM
DcMaN's Avatar
well a coolant leak could be simple. You could be lucky and it could be a hose. If its the water pump well.... then my friend you ahve something to worry about. Ive sa id this in many posts. vq30 engines are cheap with low miles i paid 350$ shipped for a 96 engine with 40k. Anything that requires you to remove the timing cover will take just as long as to swap in a new engine. I believe their both listed at 17.5 hours unless your superman :] . Good luck hope you make the right decision.
Old Oct 5, 2005 | 07:43 AM
Sounbwoy's Avatar
fix it man. I'm still accumulating parts for a complete front end rebuild. I plan to keep this car until it blows up....or falls apart....
Old Oct 5, 2005 | 08:18 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by DcMaN
I believe their both listed at 17.5 hours unless your superman :] . -
No .... My quote for my H2O pump was in the range of 3.5 hrs ..
Old Oct 5, 2005 | 08:28 AM
Biggs_02's Avatar
i would fix it, you're not gonna find a better car for the price you sell it for. The dealer wanted 3g for my honda accord that i just bought for like 10g. Selling it privately might get you a little more.
Old Oct 5, 2005 | 10:33 AM
86maxima96's Avatar
I Broke OT
ahh, then you must be Superman. how's the kryptonite treatin ya?
JJ
Old Oct 5, 2005 | 11:41 AM
wolfeg's Avatar
Fix it.
That's all relatively easy work.
Old Oct 5, 2005 | 11:52 AM
NmexMAX's Avatar
dot dot dot ...
JJ
I was saying you don't have to be superman to do it ... But you obviuosly know more about it than me so
Old Oct 5, 2005 | 07:35 PM
TheMax95's Avatar
ok here's the deal...
I checked out the car today at my brother's shop and coolant is leaking from the freeze-up plug. My bro said it's a hard job to replace but cheap. Also, the ball-joint is NOT bad. It's only the bearing, which is also cheap Thank God.
I think I forgot the big story or my maxima. I was hit real bad last year in the rear driver side and replaced the rear axle beam. Ever since, my car has been running like garbage. The accident fuuked up something with the Evap system, which is located right behind the drivers side quarter panel. The cel has been on since the accident (evap solenoid problem). I called Nissan and they said a million things might've went wrong back there and he recommended to buy a whole new evap system, which runs several hundred dollars
I also replaced the transmition which costed me another couple hundred plus a clutch.
The car runs decent now if you put aside that loud thumping from the bad wheel bearing. And the tires, well thats another couple hundred
Old Oct 5, 2005 | 07:41 PM
Sounbwoy's Avatar
Ah, the plot thickens.....I still say fix it...
Old Oct 5, 2005 | 07:46 PM
brad kay
Originally Posted by TheMax95
1996 SE 5speed
120k miles
-coolant leak
-new tires
i say sell it.. to me.. for a parts car. lol
Old Oct 5, 2005 | 07:48 PM
NmexMAX's Avatar
dot dot dot ...
You kind of failed to mentioned you got by another car.
How's the title?
Old Oct 5, 2005 | 07:54 PM
sdoherty_tjm's Avatar
if you sell it make sure you sell aftermarket stuff.
Old Oct 6, 2005 | 09:28 PM
TheMax95's Avatar
How's the title?
the title is still clean. Nothing was reported to the insurance company.
The only thing that is aftermarket on my car is the budget ypipe, which is rotting away so there's no point of selling that.
I've decided to keep the frame damaged, old, ****ttty idling, axle breaking, oil burning, gas guzzling, coolant leaking maxipad. I can't get anything better for the money right now.
My next car will be a 00/01 Audi S4 (Yes I know the turbos fail-thats why I'm getting a 50k miles warranty)
Old Oct 6, 2005 | 11:22 PM
NmexMAX's Avatar
dot dot dot ...
Your car is sorry ..
I don't care .. but Loe max might ..
Old Oct 7, 2005 | 03:50 AM
9378max's Avatar
fix it!!!!!
Old Oct 9, 2005 | 09:25 PM
TheMax95's Avatar
Who the hell is loe max?
Old Oct 9, 2005 | 09:26 PM
TheMax95's Avatar
You should care! Im getting a new car! Isn't it just sooo exciting? I'm leaving the maxima world tho
Anyway...my car is still in the shop and my bro will probably get to it on Monday. Both belts also must be changed so add that to my list of problems
pears
Sep 18, 2015 05:25 AM
Stagnet04
Sep 14, 2015 11:28 PM
