air intake and lag???
Old Oct 5, 2005 | 04:57 PM
DoNcHoYaX1's Avatar
I have a regular short ram intake, well the problem is when at low rpm's or just stepping on the gas it like lags or stalls before actually moving forward, like if there was a vaccum leak, I checked all connections and it seems fine. This happens for a couple of days then goes away. Any suggestions?
Old Oct 5, 2005 | 05:00 PM
AGRECORDS
mine too... but it's not the short ram set up.... its probly your MAF sensor going bad or having a short at times or your wire harness... that's what mine has boiled down to>
Old Oct 5, 2005 | 05:09 PM
ThurzNite's Avatar
Yup... for some reason, intakes on Maximas do that. In fact, it did the same thing on both my 1st gen Altimas too.
Jae
99grnmaxgxe's Avatar
Try putting your stock intake back on and see if it still lags, if not, then it's just the low end power loss by the short ram, if it still lags, then you got something wrong.
Old Oct 5, 2005 | 05:10 PM
2 Da Max's Avatar
well.. thats the effect of installing short ram intake.... YOU LOOSE LOW END!
Btw AGRECORDS, dont post info like that too ppl unless you know for sure
Old Oct 5, 2005 | 05:13 PM
DoNcHoYaX1's Avatar
I wish I still had the stock intake.
Old Oct 5, 2005 | 05:22 PM
NmexMAX's Avatar
dot dot dot ...
Check your ecu for ghost codes, and the 4th gen ... F/S foroum for a stock air intake.
my03maxima
Jul 28, 2024 07:40 AM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
maxima297
Sep 30, 2015 03:32 PM
MichMaxFan
Sep 30, 2015 09:18 AM
