Car not starting b/c of factory security system?
Old Oct 6, 2005 | 06:04 PM
99grnmaxgxe's Avatar
When my car stopped starting, I took it to 2 mechanics, one friend and the other a shop. None of them could get it to start, and the shop told me there was a problem with my security system. It's a factory unit, and not aftermarket. They told me that when I crank the car, the "securtiy" light should turn off, but now it just stays on while the car is cranking, and now it won't start. Any suggestions on what I should do? Thanks.
Old Oct 6, 2005 | 06:34 PM
njmaxseltd's Avatar
Sounds like the immobilizer has kicked in.
Your going to have to get the car to Nissan and have the system reprogrammed to your keys.
Old Oct 6, 2005 | 06:39 PM
Thanks, NJMAXSELTD, how and why did this happen? The day I drove it was in the morning, and it was fine, but when I went to start it around 3 in the afternoon it just would not start.
Old Oct 6, 2005 | 07:05 PM
maxman12's Avatar
you got another key, try that one.
Old Oct 6, 2005 | 07:24 PM
I do, and the other key does not work as well.
Old Oct 6, 2005 | 07:33 PM
Sounbwoy's Avatar
what about "rebooting"? disconnect batt, wait then reconnect...
Old Oct 6, 2005 | 08:40 PM
Tried that... still does not work.
Old Oct 6, 2005 | 08:46 PM
wikidminds's Avatar
try unglugging the box in the back by the antenna inside the trunk behind the carpet thing. unplug it and replug it and see what happens.
when my remote wasnt working i did dat and it works fine for me now! worth a try.
Old Oct 7, 2005 | 09:30 AM
Well, I just towed the car to the dealership and they are going to charge me $85 for just looking at it. Man, what a rip off.
Old Oct 7, 2005 | 10:09 AM
bkea's Avatar
You ain't seen ripoff yet. Wait till they call you.
Old Oct 7, 2005 | 11:07 AM
*FleXIMA*'s Avatar
yo dont bother.... get a new alarm for 150 installed it will by pass the original... worked for me!!!!!
Old Oct 7, 2005 | 04:42 PM
njmaxseltd's Avatar
You can't bypass the immobilizer system on a 99. The ignition key is chipped and programmed into the ECU. The car will not start unless it recognizes the correct key code.
Old Oct 7, 2005 | 08:30 PM
True, paid the stealership $85 to reprogram 2 keys, at least my car works now.
Old Oct 9, 2005 | 03:51 PM
battle_zone's Avatar
Do you guys know if the 98 gle key is chipped too? cuz my car aint starting either and I had a key made from the dealer
Lakersallday24
Jun 16, 2019 01:35 AM
stromm
Aug 27, 2015 04:13 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
