View Poll Results: Clutch type and grab point
Stock clutch, high grab
21.57%
Stock clutch, low grab
13.73%
OEM replacement clutch, high grab
17.65%
OEM replacement clutch, low grab
19.61%
Street/strip clutch, high grab
5.88%
Street/strip clutch, low grab
21.57%
Voters: 51. You may not vote on this poll
5spd guys - How is your clutch pedal set?
Old Oct 12, 2005 | 11:13 AM
d00df00d's Avatar
Old enuf to pick his own gears
Where is the grab point on your clutch set? Do you prefer it near the top or near the bottom?
Old Oct 12, 2005 | 12:11 PM
Jeff92se's Avatar
I'm needing a caw
High grab and you can do 9's.
Odd question. I prefer it where the factory recommends it.
Old Oct 12, 2005 | 12:14 PM
st0rm82's Avatar
is that high or low?
mine is high and i dunno if its normal since its my 1st manual car..
Old Oct 12, 2005 | 12:16 PM
Mxrider52's Avatar
I support for what?
How do you know it high when it could just be factory set up?
Old Oct 12, 2005 | 12:18 PM
Ninos_Maxima's Avatar
be the change u want2C
well I prefer mines to be really low, but its kinna high, Iono why though, on my friends prelude and my other friends crx its low. I got a question also, Can you change it?
Old Oct 12, 2005 | 12:28 PM
d00df00d's Avatar
We're just talking about whether the clutch engages near the top or the bottom of the pedal's travel, not whether it's higher or lower than stock.
Old Oct 12, 2005 | 12:36 PM
Jeff92se's Avatar
I'm needing a caw
Personally I think it's very unwise to try to make it "high" or "low". If one understands how the clutch system works.
Carlos95GXE's Avatar
i just got a 5speed swap done to my car and it engages pretty low which doesnt bother me because it feels so much different and better have a 5 speed then an auto
Old Oct 12, 2005 | 12:43 PM
d00df00d's Avatar
Yes you can. God help you maneuver tools in that tiny space (I ended up having to dismount the seat and laying face-up with my back on the floor and I barely managed it), but you can do it.
PM me and I'll email you the section of the FSM with instructions on how to do it.
Old Oct 12, 2005 | 12:47 PM
Jeff92se's Avatar
I'm needing a caw
Why would you want to?
Old Oct 12, 2005 | 12:49 PM
d00df00d's Avatar
Because you can. Same reason for any adjustment based on preference.
Is it gonna come to e-blows between you and me again, Jeffy?
Old Oct 12, 2005 | 12:53 PM
Jeff92se's Avatar
I'm needing a caw
Why?? When significant adjustments in either direct risk the proper function of the clutch. And since clutches are a big pain in the **** to change and they aren't exactly cheap, what's the exact reason again??
Are you and I gonna come to e-blows again, Jeffy?
Old Oct 12, 2005 | 01:07 PM
d00df00d's Avatar
Well, isn't that only in extreme cases? I'd think you could tweak it up or down within a certain range without adverse effects, no?
Old Oct 12, 2005 | 01:11 PM
Jeff92se's Avatar
I'm needing a caw
Tweak it to even make it worth whatever you are trying to accomplish? Probably not.
Old Oct 12, 2005 | 02:34 PM
dayglo's Avatar
i think that as your clutch goes the grab point changes...so wouldnt it be alright to edjust the pedal so that the grab point is back in its normal factory spec'd spot. mine used to be lower and now its noticably higher and i want to make it lower again.
Old Oct 12, 2005 | 02:36 PM
motocross416's Avatar
I like mine up high, otherwise I tend to let the clutch out too soon and grind the gears. Its such a horrible sound to hear
Old Oct 12, 2005 | 03:22 PM
the_3d_man's Avatar
I like mine low. It's easier to keep from rolling back on hills when you first start to go. High clutch makes it a pain cause I have to let it out before I even take my foot off the brake. (not that hills are that big a problem in Houston... but still)
Old Oct 12, 2005 | 03:46 PM
scrhale's Avatar
I don't have a manual and a high clutch point would not make me roll on a hill. Just hold the clutch under the engagement point when you are waiting. Whenever you are shifting/changing gears/doing anything with the clutch, you do not have to put it on the floor ... it is just recommended to be safe and not grind.
Old Oct 12, 2005 | 03:55 PM
THT's Avatar
THT
Throbbing member
5th gen clutch w/ low grab
Stabone's Avatar
mine has always been low even after replacing the clutch it was the same. I like having the engagement down low so I can clutch faster..
Old Oct 12, 2005 | 04:55 PM
mxzmax's Avatar
I got an act stage 3 clutch and the grab it insane and i chirp 4 gears
Old Oct 12, 2005 | 05:29 PM
THT's Avatar
THT
Throbbing member
And you're going to blow gears b/c that clutch grabs so damn hard. Our transmissions have glass gears and 3rd is particularly prone to failure. Why the hell do you need a stage 3? Are you even pushing 200whp? I think not.
Old Oct 12, 2005 | 06:15 PM
MDeezy's Avatar
My stock clutch grabs too high, it need to be adjusted.
Basically you want to have your clutch properly adjusted so it fully engages and full disengages. Too high of a grab point the clutch may not fully disengage which will kill your clutch faster. Same in reverse for a low grab point. I believe this is what Jeff is refering when he said "Personally I think it's very unwise to try to make it "high" or "low". If one understands how the clutch system works."
Old Oct 12, 2005 | 06:19 PM
Sounbwoy's Avatar
Stock clutch with high (long) pedal travel. I'd rather it engage lower myself, but I adapt and I have no problems rolling back on hills. That's what the e-brake is for.
Old Oct 13, 2005 | 07:50 AM
Flava_24/7's Avatar
Boosted Panda
I have the Exedy Stage one, and it grabs failry low with no adjustments. I like it his way. The Stock clutch seemd to grab high comapared to this one, but it never bothered me.
Now that Ive gotten used to the low engagment of the Exedy, I think going back to the OEM would drive me nuts.
Old Oct 13, 2005 | 12:12 PM
Fr33way™'s Avatar
Wild for Width
I have an ACT stage 1 and I feel like it grabs in the low range. I like it because it feels responsive. You do have to pay attention to it, but thats why I like driving the car.
When I drive my buddies '96 with OEM replacement it feels like it catches WAY later than mine and as a result I tend to rev a bit high for the first few minutes while driving it, make me feel like a nOOb hahah.
I agree with THT about the clutch being rough on the tranny, I usually quickly modulate until 3rd in hard driving. Otherwise I will bang the hell out of second (NOT so great for the drivetrain) and I have filled mounts. When I slam the 2-3 I will get a chirp and it does feel like the tranny catches very abruptly.
I can only imagine a stage 3 and what kind of stress you are putting on an achilles-heel-like Nissan 5 speed tranny.
Old Oct 13, 2005 | 12:31 PM
nismos14's Avatar
§è~® f®ÈÄk
What about the "normal" "in the middle" option? Mine is right where it should be, and I want it and like it that way. When the clutch was first put in, it was kinda of low, but after a while it got to where I feel it should be. 5th gen clutch kit by the way.
Old Oct 13, 2005 | 12:37 PM
BigLou93SE's Avatar
Yea, 5th gen Pressure Plate, and Disk...it probably tends more to the low side, but can be classified as "just right".
Old Oct 13, 2005 | 01:45 PM
joosdawg's Avatar
wow stage 3?
nismology's Avatar
It's possible to adjust the "engagement point" (within reason of course) without affecting the overall travel of the MC cylinder piston. Adjusting "pedal height" is the one that's a bad idea.
Old Oct 13, 2005 | 02:05 PM
Jeff92se's Avatar
I'm needing a caw
And run 9s?
Old Oct 13, 2005 | 02:38 PM
d00df00d's Avatar
And run 9s?
Only if you tune down the NOS timing and strengthen the injector pulse.
Old Oct 13, 2005 | 03:10 PM
nismology's Avatar
And run 9s?
Only if i do a VE swap.
Old Jul 17, 2010 | 04:23 PM
Blassmasta's Avatar
Stock with high engagement
Hey all, I'm new to the nissan thing, I fing the engagement point WAY high and VERY short. Not a progressive engagement at all. I'm adjusting but overall I find it quite awkward compared to other manuals I've owned. ('87 VW Scirocco & '85 Mustang gt). I actually had the clutch done hoping to remedy this because I assumed it was worn and causing the high engagement point. Once we got it apart i was faced with a clutch that still had 60% wear left in it. We were already there so whaddaya do ... replace it. Stock clutch kit, machined the heat marks off the flywheel, put it all back together and VOILA! exactly the same.
I like a lower engagement point, it's just much more comfortable. The leg is closer to full extension, who wants to feather a clutch with your knee up under your chest? It's stupid. First car i've ever driven like this. Hoping this engagement point adjustment i've been reading about is legit. BTW ... pretty nice ride otherwise. Loving that smooth pulling 3litre. first jap car too, i like it .
Old Jul 18, 2010 | 09:49 AM
Revo75's Avatar
Holy resurrection batman! You can adjust the engagement point, its in the FSM google it for a download link
Old Jul 18, 2010 | 10:03 AM
j-dawg's Avatar
I've been meaning to lift mine but I want to be sure that my clutch leak has been solved first. Once I've gotten used to it as it is I'll increment it upwards until I like it.
Old Jul 21, 2010 | 09:35 PM
kolbpilot's Avatar
I've never found two clutches to be alike. Supposedly mine has a 5th gen clutch bolted to the Fidanza flywheel. It feels ever so good (to me) but has very small chatter upon disengagement. It is what it is, but mine grabs not far from release off the floor, right where I like it.
maxipower
Aug 21, 2015 11:10 AM
maxima-junky
Aug 13, 2015 09:59 AM
ef9
Aug 13, 2015 01:19 AM
MikesChevelle
Aug 10, 2015 10:53 AM
