Top hats go bad often?
Old Oct 14, 2005 | 06:28 AM
filter27e's Avatar
I'm about to replace the struts on my GF's car with some GR2's on factory springs... was wondering if the strut tophats go bad on these frequently or should I just leave them? If they do I'll just replace them while I'm in there. I'm just asking because I've had a few cars where they would go out frequently on stock suspension and instantly on any stiffer suspension.
Old Oct 14, 2005 | 07:41 AM
njmodi's Avatar
Do I get a tax break?
The strut mounts can fail eventually. If you still have the original strut mounts, I would recommend replacing them and the strut bearings while you are doing the job.
Old Oct 14, 2005 | 08:10 AM
maximus_96's Avatar
what else should be replaced when replacing shocks/springs, besides strut mounts and bearings?
Old Oct 14, 2005 | 08:17 AM
wikidminds's Avatar
dust boots?
Old Oct 14, 2005 | 11:06 AM
maximus_96's Avatar
Originally Posted by wikidminds
dust boots?
oh yea, forgot that mine are all shredded up.
Old Oct 14, 2005 | 05:10 PM
Mishmosh's Avatar
Yeah, if you haven't changed the tophats, definitely do so. You don't want to repeat the labor (and then factor an alignment) for trying to save on two front tophats. They are not cheap but you will rest easy that they will last. I cheaped out and ended up redoing the fronts later...don't make the same mistake. Especially if you are lowered, the strut mount insulator takes a beating.
Old Oct 15, 2005 | 08:47 AM
TrackSmart's Avatar
DEFINITELY change:
1) Strut mounts (top hats),
2) Strut bearings (plastic ring bearing, often included with the strut mount - at least the KYB brand includes it)
3) Strut boots (rubber covering the struts to seal out dirt/debris).
I made the mistake of leaving the strut mounts (top hats) and bearings alone when changing my struts & springs. Within a year those parts were all starting to go bad - squeaking mounts, "clunking" when turning the wheel b/c of bearings losing lubrication - and more time spent fixing things I should have done from the start!
On a car of that age, those parts are bound to go bad in the near future. It's so much easier to change all of this stuff at once! It adds a few dollars to your repair, but worth every penny of future aggravation you will save!
Miket2006
Mar 1, 2021 03:55 AM
chisam14
Nov 6, 2018 08:56 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Sep 27, 2015 08:37 AM
