door lights
Old Oct 14, 2005 | 03:33 PM
AGRECORDS
door lights
hey my f#cking driver side door light went out. you know the light that comes on when you open the door..is there a fuse to each door or should i check the wires? and no the bulbs not blown!!!
Old Oct 14, 2005 | 05:24 PM
Nismo's Avatar
Both of mine have been out for the past 2 years. I would like to hear whats the deal with them too.
Old Oct 14, 2005 | 05:27 PM
95MaxRB26-DETT's Avatar
I took my bulbs out the day I brought my car home from the dealership. I don't see why you would want them, I think they're ugly. but, carry on with tea time....
Old Oct 14, 2005 | 05:41 PM
njmodi's Avatar
Do I get a tax break?
If its just one side that doesn't work, then its either the light assembly or perhaps its the little button on the inside of the door jamb that is supposed to trigger the light on/off that is stuck in the shut position (it is spring loaded)... the switch covered by a piece of black rubber and located towards the bottom of the door jamb..
Old Oct 14, 2005 | 06:53 PM
Max_N_Action's Avatar
just my drivers side doesnt work....i think im wiring is burnt out
Old Oct 14, 2005 | 07:20 PM
kbmaxima's Avatar
-sigh- i remember asking this question for almost a year without any replies. APparently, this subject has been covered more than intake threads, so i'll save you the year. // There is aparently an inherent fuse within the master window switch module that somehow got shorted and blew out just your driver's side courtesy light. Try plugging in a different master window control switch and see what happens. i'm 99& sure that's what happened.
// don't forget to swap the bulbs and light assemblies tos ee if they work on either side. // probably already did that im assuming.
Old Oct 14, 2005 | 07:36 PM
Batxel's Avatar
blah
The window switches hold the circuitry for the lights, my passanger side is out.
Old Oct 15, 2005 | 08:22 AM
wariow's Avatar
i tried swapping window switches before, and no luck.
Old Oct 15, 2005 | 09:29 AM
tuner001's Avatar
it could also be the switch that is located in the lower rear area of the door jam. if the switch is faulty, no lights would come on , but you said only the drivers side ...never mind
Old Oct 15, 2005 | 11:25 AM
AGRECORDS
its cool thanks for the input.. im just going to rewire my door to work with the passenger door with leds! later...
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
Hailstatejig
Sep 2, 2015 06:52 AM
