brakes issue
Old Oct 16, 2005 | 08:33 AM
MaxFanatik's Avatar
brakes issue
last nite i went to NYC, im standing in traffic, all of a sudden i hear a moaning sound that vibratesmy seat, does it usually udner 25mph, when i engage my brakes slowly, when i push hard on them it doesnt do it. So i thought maybe i dont got nomore pads, i looked today i still got lotta pad left. it was doing it all thru out the drivng in the city, tho when the car rests and the brakes get cold they dont do it until the heat up. Is it jsus the material?? also when i took my 2 front tires of in the park postion (auto) r the pads suppost to be touching the rotors??
Old Oct 16, 2005 | 12:20 PM
maximariceboi's Avatar
yea i have the same problem on both of the maximas..but the other is worse. i m still trying to figure out..i thinking there's something wrong with the rotors. it makes the noise when you slowly press on the pedal right?
Old Oct 26, 2005 | 06:52 PM
Louie Max's Avatar
I have the same problem =[
any solutions to this?
Old Oct 26, 2005 | 06:59 PM
njmodi's Avatar
Do I get a tax break?
1. The pads should be touching the rotor
2. The groaning is not uncommon once the brakes have warmed up and depends mainly on the pad compound. What sorts of pads are on the car?
Old Oct 26, 2005 | 07:06 PM
goldtooth's Avatar
I as well have just started to hear crunching sound, like abs turning on. But when I am braking from like 50-20 or higher or lower there is NO sound of that, ONLY when I am going from like 5mph to a stop.Sounds like there is rocks in there or something? I just got Hawk HPS for the fronts like under a month ago. Any thoughts?
Old Oct 26, 2005 | 07:43 PM
Louie Max's Avatar
I have raybestos quietstop all around... it also makes the same noise when i hit potholes or when the road is "rocky"... i thought it might have something to do with the suspesion, but its def. the brakes
Old Oct 27, 2005 | 08:12 AM
ghdtpdna's Avatar
get new brakes, or at least
that's what im gonna do
Old Oct 27, 2005 | 08:53 AM
l3ftonm3's Avatar
Have you checked the brake caliper pins, mine became rusted and needed to be cleaned and re-greased so the caliper would move freely and not just stick causing a moan to the brakes every now and then. Especially with all this rain recently in the northeast if they arent maintained rust forms real easily.
Old Oct 27, 2005 | 07:55 PM
Louie Max's Avatar
hmmmm.... thats a good possibility
thanks
Old Oct 27, 2005 | 09:31 PM
bhmax16's Avatar
I second this...unbolt the calipers from the torque members and regrease everythingggggg. May be overkill but I regrease everything everytime I change my oil
Old Nov 3, 2005 | 08:03 AM
MaxFanatik's Avatar
they fixed them selves, they were heat glazed from my hard drving, all i had to do was go easy on them and let them fix themselves out.
Old Nov 4, 2005 | 06:22 AM
stevo936's Avatar
The caliper slides might be corroded or caliper piston might be sticking. When i put front brakes on the slides were completely froze and i had the beat them out and buff all the rust/junk off them and i put neverseize on them and put them back in.
BkGreen97
Apr 2, 2016 05:47 AM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
bbsitum
Sep 11, 2015 04:55 PM
pktaske
Sep 4, 2015 08:40 AM
