clutch question
Old 10-16-2005, 01:50 PM
GreenVQ30's Avatar
clutch question
hey guys i have a 5spd 96 SE . so anyways when i start letting releasing clutch the car sttarts rolling forward without me pushing on gas. like i never seen that before usualy car stalls if u don't give it gas and let go the clutch. mine just starts rolling forward, or i stick in reverse start letting go of clutch starts rolling back. is it just me or that's how maximas are?
GreenVQ30 is offline
Old 10-16-2005, 02:19 PM
cnenov's Avatar
this is how all cars are
remember the car is idleing so you have power going to the flywheel but not the transmission (when in neutral). when you start engaging the clutch, usually you have to press on the gas at the same time to take off, but if you engage it slow enough, the idle speed (6000-8000rpm) will push the car forward. the same concept is when you are trying to take off on a hill and have to halfclutch it, so the car doesnt roll back when you let go of the brake pedal.
look it up at about.com or a similar site for a more detailed explanation
in other words - it is normal, if this didnt happen then you would have a reason to be concerned
cnenov is offline
sdoherty_tjm's Avatar
like dropping the clutch, or just starting to enter the friction point. if its the latter, then its perfectly normal
sdoherty_tjm is offline
Old 10-16-2005, 05:52 PM
GreenVQ30's Avatar
oh ok then, cause on a civic for example car just stalls
Old 10-16-2005, 06:02 PM
THT
Throbbing member
THT's Avatar
It's because we have something they don't....torque.
THT is offline
Old 10-16-2005, 06:10 PM
cnenov's Avatar
if you let go of the clutch pedal slow enough it will go
he does have a point though, a V6definetly has more torque (as in this example) than a I4. I used to drive trucks where you would have to try to stall them (let go of the clutch and press on the brakeat the same time)
cnenov is offline
Old 10-16-2005, 08:46 PM
GreenVQ30's Avatar
alright thnx guys
03-12-2020 12:06 AM
BkGreen97
04-02-2016 05:47 AM
Socalstillen
09-20-2015 11:46 PM
pears
09-18-2015 05:25 AM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: clutch question
