Programming New Key-1999
Old Oct 16, 2005 | 02:56 PM
Y So Low's Avatar
I just bought a new key from the dealer and what do I need to do to program the key?
any help appreciated. Thanks.
Old Oct 16, 2005 | 03:03 PM
Black Maxima
You needed to stay at the Dealer.
Old Oct 16, 2005 | 03:10 PM
cnenov's Avatar
i have a 95. do you really have to program a 99 key?
or are we talking about keyless entry remote
Old Oct 16, 2005 | 03:11 PM
Killer99max's Avatar
Custom Molding King!
Were talking about the chips that are in the key, ya bro you needed to have the dealer deal with that programming.
Old Oct 16, 2005 | 03:14 PM
cnenov's Avatar
what year did they start doing this?
just for my information
Y So Low's Avatar
1999 was the first year.
Old Oct 16, 2005 | 03:38 PM
nart86
yeah, u should have it done by the dealer
they charged me 140
Old Oct 16, 2005 | 07:08 PM
Y So Low's Avatar
does any one have this tsb
99-063C NOV 02 thanks
Old Oct 17, 2005 | 11:04 AM
maximaman10's Avatar
Yes you have to have the dealer program the key. You can program the remote entry flob but not the key
I'm not absolutely certain these instructions will work for your 99 but maybe it will. This was taken from http://web2.airmail.net/scutchen/max_faq/
Q: How do I reprogram the Keyless Remote?
A: Here's the procedure from the 1995 Factory Shop Manual
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Old Oct 17, 2005 | 12:53 PM
snair2's Avatar
If you still need it programmed, contact Victor at 7186759415. He will come to you, and he can program and cut the keys for a pretty low price. He programmed and cut two 5th gen keys for me for $65.
Hit him up, he works quick. Also must have all the keys you own with you when its time to program.
Old Oct 17, 2005 | 04:48 PM
Y So Low's Avatar
Thanks a lot, I'll see if he can do it. Thanks
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
maxinout93
Oct 16, 2015 02:53 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
flu2000
Sep 14, 2015 12:34 PM
