Help knocking noise when accelerating
Old Oct 21, 2005 | 09:01 AM
xmastanax's Avatar
Hi there guys, just started noticing since couple of days. when i hit the gas real slow i can hear a knocking noise, but when i put the car in neutral and hit the gas no noise. if i drive less then 10 mph i can hear it constant, does not disappear.
if anyone got any strangest idea what this could be before the Pep boys #%#$ me tomorrow let me know
thanks in advance
Old Oct 21, 2005 | 09:47 AM
xmastanax's Avatar
any advice, any thoughts
thank u
Old Oct 21, 2005 | 09:50 AM
tomservo291's Avatar
like engine lifter noise? you need to be a bit more descriptive with "knocking."
Is consistent with engine RPMs, or is it something constant.. possibly to do with your suspension or drivetrain?
Old Oct 21, 2005 | 09:59 AM
xmastanax's Avatar
it is consistent with engine rpm's i hear it when less than 10mph. the noise only comes up in slow speed. but if i keep my car going at 10mph i'll hear it, "khat, khat, khat, khat" i wish i could describe the exact sound.
Old Oct 21, 2005 | 12:50 PM
maxgtr2000's Avatar
KH3 by popular demand
In other words you hear the knock only when the wheels are rotating correct?
Old Oct 21, 2005 | 01:03 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
I too have a knocking sound while i drive, sounds metallic b/w 3K - 4K rpms. any ideas?
Old Oct 21, 2005 | 01:17 PM
NmexMAX's Avatar
dot dot dot ...
Knock/ping/detonation
Screwed fuel.
Old Oct 21, 2005 | 03:43 PM
jp_cout's Avatar
is this sound coming from the engine or from the wheels??? I have approx. the same knocking but it's coming from my rear brake pads (I didn't replaced the little springs that holds them) so it sounds like this at low speed..
Old Oct 21, 2005 | 03:55 PM
Dan's Avatar
Dan
No Longer Owns a Maxima
Try premium gas if you're not already using it, an octane booster, seafoam and/or chevron Techron additive.
Old Oct 21, 2005 | 03:58 PM
xmastanax's Avatar
thanks guys found the problem, i think so. took it to Midas once the car was lifted, both of my axle's were torn or broken right where they connect to the tire. the rubber covering was broken. i am going to get it replaced tomorrow for $313 at Pepboys. or $1000 at Nissan dealership
Old Oct 21, 2005 | 04:00 PM
NmexMAX's Avatar
dot dot dot ...
Or 180$ (AZ 75$ per side) 30$ labor, or DIY for 150$
Old Oct 21, 2005 | 04:08 PM
xmastanax's Avatar
To bad i don't know any good Nissan Mechanic's in the Los angeles side.
Old Oct 21, 2005 | 04:13 PM
NmexMAX's Avatar
dot dot dot ...
You don't need to be a "Nissan" mechanic ... I take mine to my local alignment shop when I'm feeling lazy and my finacial situation is permitting. .. try it on your own too, it's not that bad ...
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
