Permanent Rear wheel alignment damage?
Old Oct 23, 2005 | 04:10 PM
sunnyb32's Avatar
I rode the back left wheel over a HUGE crub at high speed while making a turn by accident about 3-4 months ago. Now I've tryed to have it realigned and everyone i have talked to say the rear wheel does not have adjustable alignment, i even looked in the nissan serivice/repair manual and that confirms it. Now i need to rotate and buy new tires regularly, any possible suggestions on how to get it fixed?? this happened about 4 months ago now.
95max gle 160k
thanks alot!
Old Oct 23, 2005 | 04:39 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
You cant align the rear on our cars. Someone correct me if I am wrong, but the fact that your rear alignment is off means that somehting is bent. Replacing what is bent is the only way to "re-align" your rear wheel.
Old Oct 23, 2005 | 05:11 PM
BEJAY1's Avatar
Conecarver
What's the camber and toe readings? If it's just toe then you might be able to bend it back. Otherwise it might mean new arms or beam.
Old Oct 24, 2005 | 07:47 PM
Stuntin' 101's Avatar
im no expert on alighments. but you should really post your alighment specs. if it is way out of wack, call it a day and try to find a rear beam in a junkyard. if it is slightly off, its possible to have it shimmed.
i had alighment issues since i bought this car almost 2 years ago. ive seriously had about 6 or 7 done, by various shops/ machines/ techs. ive found the biggest difference in the person using the machine. if you are not far from the nyc area, i can recomend you to guy that was the only person willing to spend a little time to get my car as perfect as it could be.
Old Oct 25, 2005 | 12:37 AM
ThurzNite's Avatar
There's a guy in SoCal that does rear suspension alignments. But you're in NY. Maybe someone there can help. Post in the regional?
Jae
Old Oct 25, 2005 | 04:20 AM
njmaxseltd's Avatar
If the rear axel beam is bent your rear alignment will be off.
You have two choices:
1) Get another rear beam
2) Sell the car.
You really should get a 4 wheel alignment so you can actually see how it's tracking. Then you can make a decision as to what to do.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
twotonezed
Aug 16, 2015 11:41 AM
