Front Right Turn Signal
Old Oct 24, 2005 | 09:31 AM
sohailnz's Avatar
My 95 maxima gle right turn signal flashing light inside the bumper has stopped working. I changed the bulb and it still wont work.. also the light on the right side of the headlight that switches on when u indicate a turn does not work as well .. i have changed bulbs but nothing is happening ... the rear indicator is flashing but at a faster than normal rate ... may be some wiring is short .. would anyone know how to fix this .. pls need help .. need this car for a driving test and they would not allow it to be used because of this proble... would highly appreciate the quick response as always ...
Old Oct 24, 2005 | 10:02 AM
NmexMAX's Avatar
dot dot dot ...
Check relay/fuse and/or wiring ...
Old Oct 24, 2005 | 10:20 AM
sohailnz's Avatar
the only fuse i saw is for both sides .. the left turn signal is working fine .. also the rear right signal is working .. the problem is only with the front right side ... is there a relay/fuse that is only associated with the front right? where is it located .. what wire do i need to check
Old Oct 24, 2005 | 10:22 AM
NmexMAX's Avatar
dot dot dot ...
Maybe check the wires that are connected to the bulb.
Old Oct 24, 2005 | 10:28 AM
sohailnz's Avatar
checked them they are connected properly... it seems they are not getting power.. can you kindly check what color wires are going into your turn signal ... i had some work done on my cars front end .. may be the mechanic screwed up
Old Oct 24, 2005 | 11:02 AM
NmexMAX's Avatar
dot dot dot ...
Strong possibility
Old Oct 24, 2005 | 11:03 AM
sohailnz's Avatar
so what can i do to fix it myself??
Old Oct 24, 2005 | 11:16 AM
NmexMAX's Avatar
dot dot dot ...
Check your blinker fluid
Check for frayed wire ends, also check all relays/fuses...
Get a wiring diagram for the car (FSM/Haynes) And study it good ...
Old Oct 24, 2005 | 12:10 PM
sohailnz's Avatar
i guess i will have to figure it out on my won .. after all .. thanks for the help
Old Oct 24, 2005 | 12:48 PM
Maxima lover
It's most likely the harness that holds the bulb. I had the same problem. The connections had just worn out and would not give the bulb power. It would be best if you had a multi-meter to use. I used the multi-meter to find out it was getting 12Volts right outside the harness, but inside it was only get about 3Volts. I took the harness apart and resoldered the connections because it was about 3AM and no store was open. You could just go buy one cheap though from an auto parts store though.
BTW, your other turn signal is flashing fast because it is designed to do that to let you know a bulb is out, so that's not a problem.
Hope this helps, ask if you have any more questions.
03VQMAX
Oct 2, 2016 09:36 AM
vybz05
Dec 10, 2015 07:38 PM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
follyburr
Aug 7, 2015 09:50 PM
