CV joint replacement
Old Oct 29, 2005 | 06:42 PM
kcryan's Avatar
So.... today while putting my chromes away for the winter i noticed i had a bad passenger side CV, i considered ordering from Raxles, but in the end, just went to autozone and for $60 got a rebuilt one with a lifetime warranty. anyway to the question, when i am trying to get the nut in the center of the lug nuts off, should i do that with the wheel on or off? also any tricks to getting it off cause it sure seems tight, and yes i got the cotter pin out
Old Oct 29, 2005 | 07:09 PM
JwaxMax99's Avatar
Go back to Autozone and get the axle socket, for a 15 dollar deposit. They also give you a big breaker bar with it. I use my impact it's fast and easier, but....And yes, take the wheel off first.
Old Oct 29, 2005 | 07:19 PM
kcryan's Avatar
i got a big breaker bar, and a 36mm socket, so ill give this a whirl tommorrow...thanks man.
Old Oct 30, 2005 | 06:48 AM
njmaxseltd's Avatar
Keep the wheel on the car and the car on the ground.
That will keep the wheel from spinning when you crack the center nut loose.
It's much easier that way, trust me.
Old Oct 30, 2005 | 01:05 PM
BigLou93SE's Avatar
Or like when doing brakes, you can wedge a bar in between lug studs, I just took off my wheel to do it yesterday.
I also bought a 4 foot breaker bar (actually it's just a long pipe) that I used in combo with a 1/2 inch breaker bar. Came off pretty easily.
Old Oct 30, 2005 | 01:12 PM
CreativeDesignz's Avatar
u need a torque wrench to put that nut back on. too much force will foul he wheel bearing and cost u $$ your not wanting to spend. trust me i did that and i regret it to this day haha
Old Oct 30, 2005 | 01:24 PM
MDeezy's Avatar
I agree with Tom, do it on the ground, especially if you have to use a brake bar and have no power tools, it will help up a lot.
Old Oct 30, 2005 | 01:34 PM
kcryan's Avatar
yea toms the man, i did it per his reccomendations, and with a little PB blaster, it came off like butter.
Old Oct 30, 2005 | 01:36 PM
torque it to spec!!!
Old Oct 30, 2005 | 01:37 PM
kcryan's Avatar
whats spec?
Old Oct 30, 2005 | 01:41 PM
MDeezy's Avatar
about 120lb/ft . . . I think dont have haynes or fsm close to me.
Old Oct 30, 2005 | 01:50 PM
kcryan's Avatar
thank you sir
Old Oct 30, 2005 | 03:02 PM
if u over torque u can mangle your wheel bearing. aka dont put it on with excessive force or an impact gun like i did haha
Old Oct 30, 2005 | 04:42 PM
BigLou93SE's Avatar
No, fsm says 174-231 ft-lbs.
Check motorvate.ca's website if you don't believe me, or check your Haynes. It is definately more than 120 ft-lbs.
Old Oct 30, 2005 | 04:52 PM
yes it is 174...
Old Oct 30, 2005 | 05:46 PM
MDeezy's Avatar
your right, I was guessing, since I didnt know off the top of my head, and didnt have my fsm or haynes, as stated.
Old Oct 30, 2005 | 06:54 PM
BigLou93SE's Avatar
That wasn't supposed to sound offensive, but reading over it again I see it could've been interpretted that way. No disrespect intended. I justknew what the values were since I replaced my driverside axle on Saturday.
Old Oct 31, 2005 | 06:50 AM
MDeezy's Avatar
Its cool, no offense taken, didnt mean to sound offensive. No harm done
Old Oct 31, 2005 | 01:56 PM
kcryan's Avatar
wow a thread where people got along, who knew?
Old Oct 31, 2005 | 07:13 PM
Black98Max's Avatar
I am having trouble getting the passenger side CV axle knocked out of the hub. Any suggestions?
Old Oct 31, 2005 | 08:15 PM
BigLou93SE's Avatar
I haven't replaced that side yet, but isn't there a trick of putting a screwdriver through the driverside and knocking the passenger side out from the driverside? Hold on, I don't have the Haynes handy, but I have a pdf of the factory service manual, so maybe they have something.
edit: I've only seen something mentioning the difference between A/T and M/T models; what tranny?
Free bump I guess.
Old Nov 2, 2005 | 05:30 AM
Black98Max's Avatar
auto, i think the screwdriver trick is for getting the left side out. I can't knock the spindle out of the right side hub. Ay ideas?
Old Nov 2, 2005 | 05:52 AM
Puppetmaster's Avatar
This write-up was for replacing the CV boots, but see if it has any info that might help ya: http://www.motorvate.ca/mvp.php/401
Old Nov 2, 2005 | 09:21 AM
JeEvE's Avatar
First time taking out the passenger axle, I was having a lot of trouble getting it out the hub also. I ended up removing that bracket it goes through because it get rusted in there. Once its out, you can beat it with a hammer and it should come off. Putting some anti-seize around it should make it a lot easier to get off next time.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
